603,853 active members*
5,159 visitors online*
    Apr 2009
    LOCKING THREADS
    Greetings everyone,
    I'm required to cut Locking Threads on a piece, and I have no idea how to do that!!!
    I have a Viper and a Colchester CNC Lathe, can anybody guide me thru this process or just give a hint?
    Thank you.
    4826
    I don't know if there is a standard for locking threads.....probably somewhere...but most that I have seen are merely a form of thread mutilation, i.e., the nut threads are deformed after the nut threads have been cut in standard fashion.
    With a cnc, it is quite easy to adjust the pitch of the male thread....maybe .001 to .002" change in the pitch per turn of the thread will make it easy to start the nut and it will require a wrench to completely engage the nut. This method might be good enough for your own personal projects, I don't say it would be good to do this for a customer, if he is expecting some sort of standardized thread.
  1. axis locking
    By doc0302 in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 12-02-2010, 12:04 PM
  2. stepper locking up
    By luther in forum DIY CNC Router Table Machines
    Last Post: 08-17-2007, 02:22 AM
  3. BCC locking up during DNC.
    By Jim Estes in forum BobCad-Cam
    Last Post: 02-07-2007, 05:03 PM
  4. Stepper locking up
    By jdholbrook in forum Servo Motors / Drives
    Last Post: 03-28-2006, 03:38 AM
