603,416 active members*
2,137 visitors online*
Thread: mazak h400
Results 1 to 7 of 7
    Mar 2009
    12
    mazak h400
    Can i speed up the b axis on this machine?(1989 Mazak H400 6-Pallet)
    B axis is the table indexer and it goes only by 1 Degree but it is very slow,
    can i speed that up? i tried to search in parameters but no luck.
    Thank You
    Dec 2006
    B Axis speed
    Quote Originally Posted by stefo View Post
    Thank You
    The table speed is set by thr M/T parameters but be very careful as it is very easy to cause table positioning faults and also damage the MV Motor controller
    Mar 2009
    12
    i have took the manual of that machine and read the parameter description and i didnt see any parameter to describe what i need.
    can you tell me which parameter it is.
    Thank you
    Dec 2006
    Thank you
    I believe you should find the M/T parameters in the front of the electrical drawing manual
    Mar 2009
    12
    in the electric drawing manual is everything on japanese,and that is a BIG problem
    Thank you on your reply
    Mar 2009
    12
    I found a electric manual on english ,and you were right the table is turning faster when I changed the parameter,
    Thank you,"nwms306," You are the best
    Hi i am sorry its not about your discussion but i have h400 also and i need its parameters coz i lost them . Is it possible to send me them ? God bless you thanks
  1. Mazak H400 y-axis falling
    By Nikola in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-22-2013, 01:12 AM
  2. Mazak H400 table indexing
    Last Post: 09-23-2012, 09:23 PM
  3. mazak H400 pallete rotation
    Last Post: 09-19-2012, 05:33 AM
  4. Kitamura Mycenter H400
    By Dave Reid in forum Kitamura
    Last Post: 12-23-2011, 10:00 PM
  5. who has an h400 ( not an HX )
    By naky15 in forum Kitamura
    Last Post: 09-01-2011, 05:16 PM
