588,567 active members*
4,913 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Can't select geometry?
Results 1 to 8 of 8
    Mar 2006
    92
    I have a good drawing and can see everything in wireframe and solid mode. I can't pick anything though. What button or setting to I have to change?
    Phoodieman
    Feb 2006
    992
    What's version? and what is the OS are you installed it in. I had try Older version to Vista and 7 it now work very well. If that is the case find older computer is the solution otherwise update your CAM
    The best way to learn is trial error.
    Mar 2006
    92
    Contour Selection
    The version is 8.0, but that's not the problem. It's a 3D part and I've been able to do anything with a lot of other parts that I wanted to. The part is there I just can't select anything. I'm thinking I might need to "explode" the part like in ACAD, but don't know where to do that at.
    Phoodieman
    Feb 2006
    992
    If you want to "explode" .... it's under Modify. Oh, BTW what level CAM do you have? I think that might be the problem.
    Jan 2010
    34
    Can you select the solid model at all ?
    Dec 2008
    3142
    In your levels dialog, does the mask column have any ticks ?
    ( this lets you select only items on that level )
    or
    Do you have any masking set before selecting items on the screen ?
    Mar 2005
    461
    It sounds to me like you have just a surface model with no "wireframe" entities...
    Select "Screen, Statistics" and post the entities reported by that function here.
    Jan 2008
    5
    Quote Originally Posted by Matt Berube View Post
    Agree! make sure what kind of entity into the file, then can sure which selection is better.
    FYI, the version 8.0 of the mastercam almost a lot of function need to select the entity first.
  1. PMC load select-Please Help
    By botts_ in forum Fanuc
    Last Post: 03-31-2011, 01:03 AM
  2. Any way to select bounding box to set wcs?
    By Shepard in forum Mastercam
    Last Post: 09-14-2009, 04:50 AM
  3. How to Select overlaping geometry
    By nfrees114 in forum BobCad-Cam
    Last Post: 07-23-2009, 10:07 PM
  4. select multiple geometry for profiling
    By kendo in forum EdgeCam
    Last Post: 11-25-2008, 06:46 PM
  5. bobcad v21 geometry won't select correctly
    By gromit68 in forum BobCad-Cam
    Last Post: 06-04-2008, 03:48 PM
