586,389 active members*
3,104 visitors online*
    Feb 2010
    Stepper motor as pressure sensor
    hey there,
    Just a simple question, I want to use a stepper motor to move down a screw and in a exact moment this screw will find opposition.
    I need to know if I can measure the current or torque to find out when is that exact moment to stop my motor.
    roughly, I want to use the stepper motor as a touching sensor or pressure sensor. Is that possible??
    I will appreciate any opinion. Many thanks.
    Jan 2009
    237
    Perhaps with an o-scope.
    Jan 2006
    738
    I think it would be easier to use a touch probe as a detector. Take a look at this page....
    http://www.vinland.com/Touch-Probe.html
    If you must use motor current a servo motor will do you better than a stepper... when they encounter resistance, the current increases to try to manintain speed. Most are rated in RPM/Volt.
    Steve
  1. Axis movement speed adjusted by pressure sensor
    By Viesturs in forum Controller & Computer Solutions
    Last Post: 05-20-2009, 12:44 PM
  2. Accurate homing switch and sensor for stepper
    By snoopy27 in forum CNC Machine Related Electronics
    Last Post: 09-01-2008, 04:48 AM
  3. Beltdrive-stepper motor-stepper motor driver
    By Georg in forum Stepper Motors / Drives
    Last Post: 10-16-2007, 10:56 PM
  4. DIY pressure sensor ? - Touch Off Plate ?
    By deleteallusers in forum Mechanical Calculations/Engineering Design
    Last Post: 06-22-2007, 10:56 PM
  5. Check Carriage Sensor or VC Motor
    By jstovall in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 10-17-2006, 01:52 AM
