587,066 active members*
3,312 visitors online*
IndustryArena Forum > CAD Software > Solidworks > set defaults in SW 2008
    For some reason I can not find where to set the defaults for SW 2008. In particular I would like to set it so every time I create a new file I dont have to set the units to inches vise the metric...
    I am sure I am just blind, can some one point me in the right direction, please?
    TIA!
    Aug 2008
    292
    Solidworks default / part assembly template
    when you have blank part options set for example inch or metric save as a solidworks part template.
    ...... in options under file locations add part template folder to search path. this way when you open new part , probably under advanced you get a selection of folders with templates.
    i often use a part template for feet , inches dimensions 0.1"
    and part template with inch only to 0.0001" for CNC.
    you also have the option to include attachments to solidworks file like word document of parts list , ordering information, or machining order of operations and setup, and a attachment of a text file of Gcode used to make a part .
    these also may not be visible if your part template is not setup to make them visible or if on automatic it may not be visible.
    this is probably the number one complaint of books on solidworks as things are not always the same a book shows because under tools options something is turned off.
  1. X4 Operation Defaults
    By WingNutz in forum Mastercam
    Last Post: 12-31-2009, 04:29 PM
  2. Changing defaults in v9
    By juxtoposed in forum Mastercam
    Last Post: 12-09-2009, 03:37 AM
  3. customer defaults
    By tarponicus in forum UG NX
    Last Post: 02-05-2009, 02:01 PM
  4. Preadator 7.0 defaults
    By orizaba in forum BobCad-Cam
    Last Post: 06-06-2008, 04:38 PM
  5. Rhino_Tools_Options Defaults?
    By robinsoncr in forum Rhino 3D
    Last Post: 06-12-2006, 05:07 PM
