586,283 active members*
3,832 visitors online*
Page 1 of 2 12
Results 1 to 20 of 27
    Jan 2010
    76
    Motor Power Woes (Please Help!)
    Im am almost finished with my first router. It is a steel framed moving gantry design with chrome plated supported shafting and open pillow block bearings. The lead screws are ACME 1/2" diamter, 10 TPI and the nuts are standard type ACME nuts. (hope to get a build log put up soon with pictures )
    I hooked up my stepper motors today (Hobby CNC 305oz steppers driven by the Hobby CNC Pro board, chain drive to the leadscrews 3:4 ratio (3 motor turns per 4 screw turns)) and I am having problems with the motors not having enough power to turn the leadscrews. This is especially aparant when trying to run a program (using Mach 3) as i see an axis trying to slowly move, but it just sits there vibrating slightly instead of slowly spinning. I can usually jog ok, but it seems like it wants to delay a little bit when starting
    I don't have my motors set at an excessive speed. Actually, the velocity and acceleration are set very low.
    I am trying to figure out why this is happening, because it seems like many people here have successfully used steppers in this capacity range. It happens with all 3 axises. The axises all slide freely when the nuts are detached.
    If i turn up the amperage to the motors, would that help? (set on about 2 amps right now).
    I am willing to redo the lead screws if thats what you all think needs to be done (would like to go with 2 or 5 start for speed, but if i dont have enough power to turn a 1 start, how can i turn a faster screw?)
    Please Help!!! I'm feeling very disappointed right now.
    Dec 2006
    406
    I'm not sure if it might be a hobby cnc issue but others here i'm sure can help you with that. I would try direct driving the screw first and see what happens. If that doesn't work try a ratio for your gearing of say 3-1. That would be 3 turns of the motor to 1 turn of the screw. With the gearing you have now you are actually decreasing the motor torque at the screw. With those motors i'd say thats a bad idea. If the motors and driver can handle more amps go as high as you can and see how much that increases your torque before you mod anything.
    Judleroy
    Aug 2008
    1166
    What are your speed and acceleration settings?
    Roughly how heavy is your gantry?
    If you remove your motors, can you turn easily move the gantry by turning the chain drive by hand? Of if you have the electronics unpowered, just turn the motors by hand to move the gantry? This would test for binding in that portion of the machine.
    Jan 2010
    76
    I don't know what the actual numbers are, but in Mach3, the velocity and acceleration bars are almost all the way at the bottom. I'd say i have it set to take at least 1 - 2 seconds to reach full acceleration, and I'm moving no more than 15 IPM.
    The gantry probably weighs 30-40 pounds.
    if i remove the motors, i can turn the lead screws by hand, but they turn harder than what i would expect, but i guess i was a little surprised that the motors had such a hard time with it. As far as the gantry itself, its not binding. Before i put the screws on, i made sure it would slide easily.
    All this leads me to believe i have excess friction in the screw assembly, which i assume is coming from the nut. Would it be a wise choice to replace the steel nut with a bronze or delrin one?
    Maybe the screws are binding on the nuts? If you remove the motors, you should be able to turn the screws from the ends with hardly any effort at all. If they are tight, that's oart of the problem.
    As for the 2 amp setting, torque is proportional to current. I don't know what your motors are rated at, but if it's 3 amps, you're only using 65% of the motors. What voltage is your power supply?
    Try setting the accel to around 4 and see if that helps. And make sure the pulse width is at least 2.
    Aug 2008
    1166
    Personally I would go with a plastic nut from dumpster cnc. That's what I use on my 1/2-10 5 start screws. Those were a little stiff when I first got them, but after running them for a while they loosened up and were easier to turn. In any case, if you can turn the screws by hand, I'm a bit surprised you're having issues. If it takes 1-2 seconds to reach full speed and you're only go 15ipm, that should be a reasonable acceleration setting and your low pitch screw should be giving you plenty of force to move a gantry that heavy. So my guess would be the nuts assuming your motors and driver are working properly. I don't personally have experience with that drive though, so maybe someone else can confirm you've got that working right. The only thing I'd suggest you check there is that the motors move fine when not attached to the screws, but it sounds like you've done that already.
    Mar 2009
    624
    Try disconnecting the gantry from the nut and see if screws turn ok then just hold the nut and feel the resistance, you should be able to hold the nut.
    If it try's to spin in your hand or stalls then it's the nut.
    If still stalls when gantry not connected and not being held then just work your way back throu the drive chain checking for other cause's or miss alignment etc.
    It doesnt take much miss alignment to rob you of power, I had a similar problem but my problem showed at speed when motors were at the end of there torque and the miss alignment was only 3/10th mm or so.!!
    May 2009
    264
    Yeah...misalignment will get you....mine was off my a hair and the machine worked great until I got to the extreme's then it would stall....(nuts).
    Setup and alignment took longer than building my machine.....but all that test, measure, align....repeat paid off...:cheers:
    Sep 2008
    83
    15 IPM on 305 oz-in motors is WAY too low.
    This is either misalignment issue or your motors not getting enough juice. What's your power supply voltage/current is?
    ______________________________________________
    My DIY CNC machine plans at www.8020CNC.com
    Jan 2010
    76
    Thanks to all who answered! I found out the power I was supplying was less than half of the rated max. I guess i forgot to set it higher after the initial board testing. Now I'm running ok at 30 IPM with no lost steps as far as i can tell. I think in the future I will upgrade to Roton ballscrews, but for now i have a working machine Check out my build in the build log!
    Edited:
    http://www.cnczone.com/forums/showthread.php?t=98950
    Mar 2009
    624
    Quote Originally Posted by basskitcase View Post
    Cant see it post a link.!!
    Sep 2008
    83
    30 IPM is still too slow. I'm using the same 1/2-10 ACMEs as you do, and my nuts are from dumpstercnc (but this really doesn't matter for now). I'm getting 150 IPM on rapids. And this is with 280 oz-in motors.
    I'd check the alignment. It looks like your screw and nut are off.
    __________________________________________________ ___
    Jan 2010
    76
    I dont understand how you can be getting 150IPM with 1/2 - 10 leadscrews using a stepper motor (unless you have a really good driver or are gearing it up). You would have to be rotating at 1500 RPM, which i understood to be way over what a stepper will typically do. I don't think mine will go that fast unhooked! What driver are you using for the stepper?
    Sep 2008
    83
    Yes, I'm getting 1500 RPM. No, this is not way over what a stepper can do. Steppers are usually rated for pps - pulses per second. At high RPM a driver works in a full-step mode. With 200 steps motor this gives 200x1500/60=5000 pps. Looking at the torque curve for my motors, at 5000 pps they have approx 1.8 N/m torque.
    Now, even if the driver doesn't work in full step, but in 1/10th step (microstepping), we'll get 50000 pps, which is still achievable with steppers. At 50000 pps my steppers have 0.4 N/m torque, which is enough for rapids.
    I'm using Gecko G540 as a driver and Keiling 284 oz-in motors. My PSU is 48V 15A.
    At first, I had my axis misaligned, and couldn't get more than 60 IPM from my machine. After I aligned the screw and nut, this dramaticaly reduced the load on motors and they were able to drive the axis much faster.
    Jan 2010
    76
    Ok, I'll double check my screw/nut alignment. For what its worth, i think it could be improved a little. Thanks for the input.
    Mar 2009
    624
    It's worth a lot, binding and miss alignment rob power quickly.
    But I think you have more issue's than just that if all you can get is 30ipm, i suspect your driver setup and Ps are more the cause.
    My 490 oz/in Nema 32 steppers will spin at 1650rpm before they stall and run fine at 1500rpm and smaller Nema 23's are known to spin faster than larger motors.
    Tell us more info about the drivers IE: Volts, amps stepping and stepper specs again V's & A's also the PS being used and maybe we can help you track down your problem.?
    Looked at your build log and other than the wood used to mount Z carriages into it looks ok and should easily go over 30ipm.
    Do you know the weight of the gantry.? this will help with calculating estimated speeds.!!
    cheers.
    Jan 2010
    76
    Yeah, the wooden components will be replaced with steel over time...
    The driver i am using is the hobby CNC pro board. running 1/4 step, with 36V input voltage. Power supply consists of 10A 24VAC transformer with bridge recitifier and capacitor (don't remember the capacatance, but it was the capacitor that hobby cnc provided for that size power supply).
    when doing initial motor testing, with no load attached, the motors never seemed to go overly fast before stalling (guessing around 500 rpm???) (this was running at half their rated amperage though)
    Has anyone here ever had issues running higher RPMs with the hobby CNC board or Hobby CNC 305oz steppers?
    Oct 2005
    1237
    Quote Originally Posted by hemsworthlad View Post
    cheers.
    Very true. I had a very stiff Z axis on my JGRO. When I took it apart to see why the lead nut was so stiff, it became smooth as silk to turn. I ended up moving my stepper 1/8" and the realignment fixed the stiff lead-screw/nut stiffness.
    Mar 2009
    624
    Right so PS is ok will give you near 36v when rectified.
    Really would help to know stepper specs and how they are wired parallel or serial. . . . I suspect they may be wired Bi polar serial this would explain a little to loss of torque at speed and also low power requirements.
    Also what amps are the drivers set to.?
    Mar 2009
    624
    After looking at HobbyCnc site I,m pritty sure that you are running these motors serial and this would explain the lack of speed and torque.
    I would seriously consider looking at replacing your drivers with better drivers that can run these motors Bi-parallel and a new PSU to match.
    A G540 would be perfect and you wouldn't regret it. . . . Would turn this machine from a donkey into a stallion.!!
    You will never get speed and torque with these drivers in this arrangement.
Page 1 of 2 12
  1. More Stepper Motor Woes
    By derekj308 in forum Stepper Motors / Drives
    Last Post: 09-15-2020, 12:35 AM
  2. Stepper Motor Power
    By kylecroft in forum Stepper Motors / Drives
    Last Post: 05-03-2007, 05:24 AM
  3. Power to DC motor?
    By ZipSnipe in forum CNC Machine Related Electronics
    Last Post: 06-04-2006, 06:53 AM
  4. power of milling motor
    By ML1 in forum Uncategorised MetalWorking Machines
    Last Post: 10-22-2004, 11:26 PM
  5. what is the power of this motor?
    By SJ781 in forum Servo Motors / Drives
    Last Post: 05-18-2004, 04:59 PM
