588,487 active members*
5,374 visitors online*
IndustryArena Forum > Community Club House > Heads Up - Article about building CNC Milling Machine
    Aug 2003
    253
    Magazine article about building a CNC milling machine:
    Servo Magazine (by the "Nuts & Volts" magazine publishers)
    April Issue, 2005
    ABSTRACT:
    A Hobby CNC Milling Machine
    by Lester "Ringo" Davis
    A computer numerical control (CNC) machine is basically a milling machine with motors attached to each axis with a computer controlling them. A small three-axis CNC milling machine can cost up to $35,000.00, and after looking at what it did, I decided to try to build one for slightly less money — about $34,500.00 less, to be exact. This article is not intended to be a recipe for building a copy of my design, but for giving you ideas on how to build your own using some of the techniques I found and avoiding some of the mistakes I made. I’m an electrical engineer, so machining is not part of my background, but if I can make this work, then so can you. I did have access to a small machine shop with a band saw, lathe, and a milling machine.
    I wanted my machine to be able to cut plastic up to four-inches thick, thin metal, and also be able to make printed circuit boards (PCBs). I wanted to work on material at least 12-inches wide and 18-inches long, and I was looking for precision in the range of 0.001 inch. With those ideas in mind, I started looking at what materials were available ...
    Jun 2005
    10
    Looks like there was a part two in the may 2005 issue. Did anyone here see these articles? I was thinking about ordering the back issues.
    Apr 2004
    439
    Only thing bad about stories like this is when they say the price of a normal mill/router like "upto $35,000" and then say i build mine for $500 :P That $500 really has nothing to do with a $35,000 mill/router :P Ebay can only get things so cheap . Even nice set of geckos is half the price right there. I wouldn't have said anything but i seen a couple of stories do this.
    But Anyway Thank you for the link and the heads up on the story
    Apr 2003
    470
    I did not read the articles, but I did just order the back issues. So hopefully I'll have them in a few days to report back as to what the deal is with it. I've been wanting to add an additional machine to the shop. But you can take a look at the basic (really basic) design from the zip files on the site. It includes a schematic/pcb layout for a driver board as well.
    Nathan
  1. Feedback 932 cnc milling machine
    By Chompalot in forum CNC Machine Related Electronics
    Last Post: 10-07-2012, 09:18 PM
  2. Top Tech CNC Milling Machine from penn tool
    By wisp in forum Knee Vertical Mills
    Last Post: 03-29-2011, 12:43 AM
  3. New CNC Machine - Building Stage!
    By JavaDog in forum CNC Wood Router Project Log
    Last Post: 08-10-2007, 03:56 AM
  4. Student Building a CNC Machine for Metal
    By MetalCNCing in forum Knee Vertical Mills
    Last Post: 12-19-2005, 01:28 PM
  5. best tooling purchases made for building your CNC machine
    By pminmo in forum DIY CNC Router Table Machines
    Last Post: 04-10-2004, 03:28 AM
