603,895 active members*
4,644 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > mini-mill z-axis/column rigidity
Results 1 to 6 of 6
    Feb 2010
    Hi guys and gals,
    I have an HF x2 mini-mill and want to make the column more rigid. I don't need to tilt the column, so I am planning to brace it to the bench. I was thinking of 2 x 2 tubing with triangulation out to outriggers to the sides, and maybe out back. The bench is rigid and should have plenty of space. I've been searching for pics, but not having any luck. I'm sure there are plenty of pics here, and maybe better ideas. Could you point me to a thread or post a pic?
    BTW: the column is "stock" except for a DRO on the right, which I can move, and all the torsion lift and its' associated gagetry are gone. I have added an extended rack for more travel.
    TIA,
    jon
    Nov 2009
    724
    check out crevice reamers z axis brace for the X3 crevicereamer.com
    Mar 2008
    3655
    Quote Originally Posted by knudsen View Post
    Hi guys and gals,
    I have an HF x3 mini-mill and want to make the column more rigid. I don't need to tilt the column, so I am planning to brace it to the bench. I was thinking of 2 x 2 tubing with triangulation out to outriggers to the sides, and maybe out back. The bench is rigid and should have plenty of space. I've been searching for pics, but not having any luck. I'm sure there are plenty of pics here, and maybe better ideas. Could you point me to a thread or post a pic?
    BTW: the column is "stock" except for a DRO on the right, which I can move, and all the torsion lift and its' associated gagetry are gone. I have added an extended rack for more travel. jon
    Hi Jon. Welcome to the Zone!
    It sounds to me like you have an X2, not an X3. There are some good suggestions for X2 column improvement on Hoss's site:
    http://www.hossmachine.info/Shop_Info.html
    CR.
    http://crevicereamer.com
    Too many PMs. Email me to my name plus At A O L dot com.
    Feb 2010
    Thanks for your answers. That's right, it's an x2. Wish I could edit the title, but I can not Perhaps a mod can change that.
    Crevice Reamer's z-axis brace is close to what I had in mind. Going off the top like that, I wouldn't have to move the DRO.
    Feb 2007
    4550
    Post
    Knudsen,
    You can edit the title, see attached images for direction.
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Feb 2010
    Thanks, Jeff!
  1. Replies: 1
    Last Post: 05-24-2009, 07:43 PM
  2. X3 column rigidity?
    By lagfish in forum Benchtop Machines
    Last Post: 12-23-2008, 04:51 AM
  3. Taig Z Axis Column Torque? Manual?
    By cwm9 in forum Taig Mills / Lathes
    Last Post: 11-18-2008, 05:00 AM
  4. HARBOR FREIGHT small round column mill to a square column conversion.
    By motomitch1 in forum Vertical Mill, Lathe Project Log
    Last Post: 12-01-2005, 05:24 PM
  5. machine rigidity
    By frankv in forum Mechanical Calculations/Engineering Design
    Last Post: 05-11-2005, 01:30 PM
