588,245 active members*
3,925 visitors online*
    Jul 2009
    108
    Unhappy seeking any and all advice
    We are tig welding 1018 mild steel tubing together with another 1018 tube that has had a solid lug soldered to it approx. 3inches from the weld zone. We are getting weld porosity in the center and edges of the weld. The flux we are using is high temp black flux. We are trying to clean the flux out of the pipe but some residue remains. WE are using ER 7OS-2 tig rod. Any advice is welcome,
    Kling
    Jan 2006
    2985
    can you weld before soldering?
    can you use another type of flux which can be more easily removed?
    have you used acetone or similar to try and clean it?
    are you using enough shielding gas AND purging the inside of the tube?
    If I had to guess, I would say you are not purging the inside of the tube and that is your biggest problem.
    Matt
    Jul 2009
    108
    Thanks keebler for the help, we are trying a few of your suggestions.
  1. Seeking advice on GE/Fuji AF-300 VFD
    By jimjovan in forum Phase Converters
    Last Post: 04-05-2010, 02:21 AM
  2. Prospective Machinist Seeking Advice
    By Septimius in forum Community Club House
    Last Post: 02-26-2010, 07:57 PM
  3. SEEKING ADVICE
    By kling8 in forum WoodWorking Topics
    Last Post: 11-19-2009, 09:19 AM
  4. Seeking Minilathe QCTP Advice
    By HankB in forum Mini Lathe
    Last Post: 02-09-2008, 03:29 AM
