603,369 active members*
3,607 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > VM1 spindle clamp/unclamp error
    Jan 2008
    9
    Hello,
    I am getting an error message on my 2003 Hurco VM1 when I try to unclamp a tool from the spindle. It will release the tool but it promptly faults out and causes me to go into the menu to clear out the error before being able to insert another tool in the spindle. This is the error it gives:
    Both spindle clamp and unclamp inputs detected. Enter ATC & Machine Diagnostics to clear error.
    Has anyone seen this before? Any tips for repair?
    My machine sat without use for about 2 months and after the sitting, this problem started happening.
    -BSF.
    Feb 2008
    48
    Try this : Open up the head cover, and above the spindle is the unclamp cylinder, the Top Limit switch is stuck ON.
    Use a little WD40 and work the plunger up down to free it up.
  1. M-code for Chuck Clamp/Unclamp
    By stuby in forum G-Code Programing
    Last Post: 05-06-2025, 10:09 AM
  2. Spindle Tool Clamp/Unclamp Alarm
    By Q12321 in forum DNC Problems and Solutions
    Last Post: 03-14-2025, 02:33 PM
  3. Clamp Unclamp Problem VMC
    By 24kilo in forum Fanuc
    Last Post: 01-18-2010, 11:44 PM
  4. clamp and unclamp AB axis in PB command
    By NCexplorer in forum UG NX
    Last Post: 06-10-2009, 03:53 AM
  5. Spindle clamp
    By jo.long in forum Benchtop Machines
    Last Post: 01-13-2009, 12:21 AM
