603,879 active members*
4,724 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Length and Diameter offsets
    Oct 2009
    77
    I'm using cutter compensation in control, so that my code outputs G41/G42. The way I've seen it work on controls is that the length offset and diameter offset are equal to the tool number. So if tool number = 2, the H = 2 and D=2
    To me this makes sense since you have to correlate in on your machine when you set up your tool #2.
    Now why would you want to add to the offset number for the length and diameter. i.e. I read somewhere on the net that on a fanuc ,If you are using tool#2 the length offset = 2, but the diameter offset = 22, so in Mastercam you add "20" to the diameter offset.. My question what is the purpose of entering 22 and not 2 ( from the tool number) ? Is it because the fanuc control does not have many offsets, i.e. the first 20 offsets are for the 20 tools in the carousel and therefore they are only for the length offsets, and therefore a new "page" is needed for diameter offsets ?
    Hope I'm making sense ?
    Mar 2005
    461
    Exactly right. Only on cheesy older models though...
    Pretty sure all the newer Fanucs have no need for all that confusion.
    Oct 2009
    77
    Thanks Matt,
    This forum is the best, and slowly but surely I'm learning a lot !
  1. Fagor 8055 tool length offsets
    By bobcor in forum G-Code Programing
    Last Post: 12-02-2010, 02:30 AM
  2. Tool length offsets
    By gbpacker in forum Fadal
    Last Post: 09-29-2009, 04:23 PM
  3. setting lathe tool length offsets on ah ha control
    By machinewerks in forum G-Code Programing
    Last Post: 02-28-2007, 04:09 AM
  4. Full length small diameter HR Rods Sandblasted
    By cheapo in forum Mass finishing equipment/media/strategies
    Last Post: 10-12-2006, 01:43 AM
  5. Tool Length offsets supported?
    By HomeCNC in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-01-2004, 05:38 PM
