so, i read alot of the stuff in the eg thread and am ponder how to apply it.
i want to use it to fill the column on a bf20 (grizzly g0704) right up, with a wood plug to keep a path for the ball screw.
since this is a non structural application and only for damping and mass, im wondering if its something moderately simple to do.
basically, block off the bottom, instert the plug (2 piece with appropriate draft angles), then premix up some granite and epoxy and pour it in and pack it as tight as possible from the top.
sound right?
what type of mix is best in a filler application that wont have vibration to compact it?
also, what do you use on the plug as a release agent? just the same mould release that youd use on fibreglass moulds?
