586,111 active members*
3,202 visitors online*
    Jan 2009
    44
    Anilam 3300 Motherboard died!!
    So I got the part set up, walked away for just a second and when I came back, the control was rebooting. From then on, that is about as far as it would get. It would show the hard drive on boot and it would just hang.
    Called Anilam and they said the motherboard is bad. Found a new MB of a different manufacturer (IOWA-MARK-533-128MB-R11). Got the new MB installed and had to reinstall the Anilam software because the video was all screwed up.
    Finally seemed to get it all working but it does not see the limit switches. It also pops up with "I/O nodes found do not match nodes specified as installed"
    I also have a remote MPG and start/stop that does not function. I am assuming those are the nodes that are not configured properly.
    I reloaded the parameters from the backup copy made before it died.
    It won't let me into the advanced I/O parameters. I have a feeling that is where I need to do some configuring.
    Any thoughts? I am at a loss.
    Thanks! :cheers:
    Jun 2010
    Hi, Did you manage to solve this problem and is your machine now running?
    I have a similar problem!
    Jan 2009
    44
    Sure did! I had to replace the motherboard. The one that I got was not configured to run with the Anilam I/O. I ended up replacing it with one that was an upgrade so it had more ram and a faster processor. It fired right up and has been running ever since.
    I purchased it through ICP America. The Part number that I got is JUKI-745E-R3.
    Good luck!
  1. Anilam 3300 mk or Mach III
    By rktman8888 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-16-2011, 07:21 PM
  2. anilam 3300 mk hard drive died
    By nealg in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-19-2010, 06:50 PM
  3. anilam 3300 help
    By ninja11zx in forum CNC Machine Related Electronics
    Last Post: 11-18-2010, 07:21 PM
  4. anilam 3300 trouble
    By ramac in forum Mach Software (ArtSoft software)
    Last Post: 11-10-2009, 04:08 PM
