587,687 active members*
3,561 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > SHS within SHS slideway, can it work?
    Jan 2009
    265
    Hi, got an idea of 150 x 150 x 9 SHS tube outer (sliding) and an 125 x 125 x 9 inner (fixed) with four 3.5mm brass plates wear strips.
    As a slideway, provided all the taper is machined out of the inner SHS and the wear strips have proper lube and clearances.
    Question#1 What length the outer sliding tube should be?
    Question#2 Will the friction be unacceptable?
    Question#3 Is this sound practice or not?
    Many thanks,
    Derek.
    Jan 2009
    265
    no takers?
    Jan 2009
    265
    All my posts are becoming like a fart on a crowded train, everybody riles at the stench and i smuggly breath it in!!!
  1. Is the slideway lubrication adjustable?
    By mattme in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-26-2016, 03:32 PM
  2. Speed Limitation of Traditional Slideway??
    By Shooter7 in forum Linear and Rotary Motion
    Last Post: 10-14-2011, 08:35 PM
  3. Work holding options to hold thin round work? .024, .046 etc
    By KyleH2 in forum MetalWork Discussion
    Last Post: 06-07-2010, 07:22 PM
  4. Replies: 8
    Last Post: 04-16-2009, 01:39 AM
  5. slideway support rails + oilite bearings
    By colormecnc in forum Linear and Rotary Motion
    Last Post: 07-13-2007, 09:03 PM
