587,754 active members*
2,811 visitors online*
IndustryArena Forum > CAD Software > Uncategorised CAD Discussion > Side by Side errors starting ST2
Results 1 to 8 of 8
    SE ST-2 on Windows 7 64bit.
    It used to work but something happened..
    I tried repair, then uninstall-reboot-install. No help.
    Using sxstrace.exe in DOS i get:
    ERROR: Cannot resolve reference Microsoft.VC90.MFC,processorArchitecture="amd64",p ublicKeyToken="1fc8b3b9a1e18e3b",type="win32",vers ion="9.0.21022.8".
    From a lot of googling that apparently has to do with Visual studio debug routines and suggested installing Visual Studio 2008 trial which unfortunately is now removed from MS only 2010 & 2012 are now available. I found SP1 and ran the repair option but still not working.
    I also did a full repair install of Windows-7 but no luck.
    Below is the last section of the sxstrace log
    HELP!
    Thanks in advance,
    Bertho
    INFO: Resolving reference Microsoft.VC90.CRT.mui,language="*",processor Architecture="amd64",publicKeyToken="1fc8b3b9a1e18 e3b",type="win32",version="9.0.30729.6161".
    INFO: Resolving reference for ProcessorArchitecture amd64.
    INFO: Resolving reference for culture en-US.
    INFO: Applying Binding Policy.
    INFO: No publisher policy found.
    INFO: No binding policy redirect found.
    INFO: Begin assembly probing.
    INFO: Did not find the assembly in WinSxS.
    INFO: Attempt to probe manifest at C:\Windows\assembly\GAC_64\Microsoft.VC90.CRT.mui\ 9.0.30729.6161_en-US_1fc8b3b9a1e18e3b\Microsoft.VC90.CRT.mui.DLL.
    INFO: Did not find manifest for culture en-US.
    INFO: End assembly probing.
    INFO: Resolving reference for culture en.
    INFO: Attempt to probe manifest at C:\Windows\assembly\GAC_64\Microsoft.VC90.CRT.mui\ 9.0.30729.6161_en_1fc8b3b9a1e18e3b\Microsoft.VC90. CRT.mui.DLL.
    INFO: Did not find manifest for culture en.
    INFO: Resolving reference Microsoft.VC90.MFC,processorArchitecture="amd64",p ublicKeyToken="1fc8b3b9a1e18e3b",type="win32",vers ion="9.0.21022.8".
    INFO: Resolving reference for culture Neutral.
    INFO: Find publisher policy at C:\Windows\WinSxS\manifests\amd64_policy.9.0.micro soft.vc90.mfc_1fc8b3b9a1e18e3b_9.0.30729.6161_none _a554a30de6a6e582.manifest
    INFO: Publisher Policy redirected assembly version.
    INFO: Post policy assembly identity is Microsoft.VC90.MFC,processorArchitecture="amd64",p ublicKeyToken="1fc8b3b9a1e18e3b",type="win32",vers ion="9.0.30729.6161".
    INFO: Attempt to probe manifest at C:\Windows\assembly\GAC_64\Microsoft.VC90.MFC\9.0. 30729.6161__1fc8b3b9a1e18e3b\Microsoft.VC90.MFC.DL L.
    INFO: Attempt to probe manifest at C:\Program Files\Solid Edge ST2\Program\Microsoft.VC90.MFC.DLL.
    INFO: Attempt to probe manifest at C:\Program Files\Solid Edge ST2\Program\Microsoft.VC90.MFC.MANIFEST.
    INFO: Attempt to probe manifest at C:\Program Files\Solid Edge ST2\Program\Microsoft.VC90.MFC\Microsoft.VC90.MFC. DLL.
    INFO: Attempt to probe manifest at C:\Program Files\Solid Edge ST2\Program\Microsoft.VC90.MFC\Microsoft.VC90.MFC. MANIFEST.
    INFO: Did not find manifest for culture Neutral.
    ERROR: Activation Context generation failed.
    End Activation Context Generation.
    Dec 2008
    4548
    Run both of the redistributables in this order listed:
    Download Microsoft Visual C++ 2008 Redistributable Package (x86) from Official Microsoft Download Center
    Download Microsoft Visual C++ 2008 SP1 Redistributable Package (x86) from Official Microsoft Download Center
    This "should" fix the side by side error. Windows will force the use of the newer one, even if the app did a failed point to a no longer listed one.
    The info you were steered towards regarding Visual studio, is info for the app developers and the compiling/distribution of their app.
    Thanks Burrman for a fast reply.
    I tried the sequence of downloads as suggested. In both cases it gave me the option to "repair" which I did.
    Unfortunately I still get the same Side by Side error message.
    Bertho
    Dec 2008
    4548
    I tried that too but unfortunately I still get the error.
    Any more suggestions?
    Thanks,
    Bertho
    Dec 2008
    4548
    Quote Originally Posted by Bertho View Post
    Thanks,
    Bertho
    Yup, one more here:
    Download Microsoft Visual C++ 2008 Service Pack 1 Redistributable Package MFC Security Update from Official Microsoft Download Center
    Hurray!! Success!!
    You are a hero! I have been fighting this problem for a long time.
    Now SE is working again and I am very happy.
    Bertho
    Dec 2008
    4548
    Hey Bertho,
    Great news!
    A note for this. If you ever do "restore or OS re-install" type operations, you should go to windows update and run that continuously until it says no more......
  1. Compare Mazak programs side by side with diferences highlighted.
    By Raybeamerson in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-12-2017, 05:24 PM
  2. Adjusting CRT Monitor side to side
    By tsrnewlin in forum Haas Mills
    Last Post: 09-14-2010, 01:11 AM
  3. Replies: 13
    Last Post: 07-13-2010, 05:23 PM
  4. Z-axis - mounting rails on spindle side, rather than tower side
    By guru_florida in forum Linear and Rotary Motion
    Last Post: 02-01-2008, 01:54 AM
  5. mounting linear rails side by side
    By 50062040 in forum Linear and Rotary Motion
    Last Post: 10-24-2005, 01:49 PM
