588,288 active members*
4,970 visitors online*
Page 1 of 6 123
Results 1 to 20 of 109
    Jul 2003
    123
    my new sidecar
    just got this home 600 bucks came with drill chuck no key
    but its painted NASA oange really pokes you in the eye
    pealing in spots to
    just collecting cnc servo drive equipment
    bought 4 of them 50 VDC 2100 RPM SERVO MOTOR
    2 have 5/8 shafts?
    2 have 1/2 shafts?
    trouble all ready
    got to get
    The E4 series from USDigital. 250 Cpr encoder
    power supply
    geco 320 drive
    got seperately
    Rotary table and a 6 inch vice 2" boring head
    set of Morris taper #3 collets 3/8 draw bar hole though
    machinje came with a 7/16?
    will have to post pictures
    just collecting now its cold out in the garage
    Attached Files Attached Files
    Jul 2003
    123
    SPECIFICATIONS
    Power: 1.5 HP
    Swing: 15 7/8"
    Maximum spindle travel: 5"
    Column Diameter: 4 1/2"
    12 Drill speeds
    Speed Range: 120 ~ 2580 RPM
    Spindle taper: MT3
    120V - 60 Hz
    Chuck size: 1/8" ~ 5/8"
    Shipping Weight: 700 lbs
    Jul 2003
    123
    power supply ?
    one for each axis
    http://www.powersupplydepot.com/15081-PS.htm 4.2 amp 48 volts
    or
    http://www.powersupplydepot.com/12425-PS.htm 3.2 amps 48 volts
    or
    will this run them all
    http://www.powersupplydepot.com/6646-PS.htm 10 amps 48 volts
    150 bucks ?
    what about 5 volts
    its great to know what not to do
    as we can play a game of Chest with the stepper motors that we have
    all different sizes colors different Wires got a bunch of stuff all ready
    I been getting liner guides from work that have been thrown away
    for what ever reason
    Jul 2003
    123
    this is it
    this is a picture of the mill I got
    I picked it up in fort worth Ind and took it to lansing in a
    ranger 230 miles
    the repair shop called and said that my back axel is fixed
    and come on in and lets talk about it I got good news and Bad
    I just had them put new brakes on [:{ but the truck has 125,00
    on it and I was dooing donuts earler
    only look with one eye
    stand is 3 X 3 1/8 thick wall welded 1030 mild steel
    Attached Thumbnails Attached Thumbnails nasa mill.jpg   nasa mill on revers switch.jpg   nasa mill no revers switch.jpg   nasa mill left.jpg
    Mar 2003
    2139
    Sweet. You bought it used or new?
    Eric
    Quote Originally Posted by sidecar82
    ranger 230 miles
    I wish it wouldn't crash.
    Jul 2003
    123
    mill new
    bought it to
    Homier Distributing
    325 Hauenstein Road
    Huntington, IN 46750
    Phone260)356-0816
    Hours: M-F: 8am - 7:30pm
    Sat: 8am - 6:30pm
    Sun: 11am - 4pm
    I called and asked if they had one in stock and they said yes
    shipping was going to be 168 dollars and it wasent to my door step
    they said they have a hilo and can put in the back of my ranger
    http://www.homier.com/default.asp?dp...tail&sku=03988
    Jul 2003
    123
    vice and rotary table
    I got these at Kitts a local tool store
    Jul 2003
    123
    6 inch vice sides are ground square so that vice can be placen on its side
    8 inch rotary chinese imitation Kitts said that if the handel is cranked
    and cranked so that the table is rotated 760 dregees or more
    eventually it will jam? any body hear of that?
    Jul 2003
    123
    50 volt DC motors
    Jul 2003
    123
    how about 3 of these for power supply
    they are $4.95 24 volts 2 amps
    http://www.goldmine-elec-products.co...item=3&mitem=4
    Jul 2003
    123
    another choice
    http://www.mpja.com/productview.asp?product=12418+PS
    $39.95 24 volt 4.5 amp
    Jun 2003
    1365
    I dont think you would be able to power one of those motors with 3 of them.
    Take a look at the 10a 24v transformer or 2, maybe more from mpja
    Jon
    Jul 2003
    123
    Is this right volts X Amps = Watts
    first one 24X2=48 watts
    last power supply 24 X 4.5 = 108 watts
    http://www.mpja.com/category/Four_or...P_15057_PS.asp
    28x14=292
    Jun 2003
    1365
    Sidecar, do a lot of reading
    Youll have to figure out the power requirements for those motors, how they work along with the drives and everything else, maybe start a thread for your own conversion.
    Jon
    Jul 2003
    123
    Jul 2003
    123
    48 volt DC Voltage Adjustment 2 models 41-56 Volts and 20-26.4 Volts
    $169.00
    http://www.usdigital.com/products/ps320/
    thinking of 41-56 volts
  17. #17
    Aug 2004
    2849
    I suspect those Ametek motors are rated at 50 VDC at a maximum of 10 to 12 amps. So, at a minimum I would find a 48 VDC power supply that will supply 30 to 40 amps. These should be commom Telco power supplies. Or buy yourself a toroid, a bridge rectifier, and some Sprague electrolytics caps 47,000 mfd at 75 VDC from http://www.mouser.com The toroid are available on ebay for about 40 bucks...you'll need one that has two 37 VAC secondaries at 15 amps that you will need to parallel.
  18. #18
    Jul 2003
    123
    here is another power supply
    24 volt at 8 amps 59.00 dollars
    http://www.mpja.com/category/Single_...Y_15080_PS.asp
  19. #19
    Jul 2003
    123
    here is a real hot rod
    plan on running 2 motors on the +28 and other 2 on -28
    what you think?
  20. #20
    Jul 2003
    123
    e2
    I ordered e2-250-125 today from us didital
    and some cables ca-3934-6ft
    ordered last week end
    timing pulleys and belts L size for X and Y
    getting ready to order the 28 volt 14 amp power supply
    for a 100 bucks
    thrust bearings from redtool.com
    page 357 Double Row - Angular Contact
    they are about 30 bucks each
    thay have Alum stock too
    Stock Journal Ends
    ball screws ready to go
    wedin.com/end_types.html
    hpoe i dont
    dont make a misstake in the order
    Tested out computer that will be used
    Need to get 1/8 reamer and drill for it and some dowels too
    May start drilling holes in the ends of the dc motors
    Question could the dc motors be used on a wind mill
    to charge battries then if a DC spindle drive is used?
    I would be Plug it in the wall less
    did you here about the guy that converted every thing in his house to
    12 volts and got his electricty from the phone lines !!!!
Page 1 of 6 123
  1. Mill/Drill conversion coming right up!
    By balsaman in forum Vertical Mill, Lathe Project Log
    Last Post: 04-30-2009, 02:04 AM
  2. Square Column Mill/Drill Conversion
    By Jay Kyle in forum Vertical Mill, Lathe Project Log
    Last Post: 08-23-2005, 07:42 PM
  3. Harbor Freight Mill/Drill Conversion Log
    By Halfnutz in forum Vertical Mill, Lathe Project Log
    Last Post: 04-14-2005, 04:56 AM
  4. First Impressions for CNC mini mill conversion
    By cncadmin in forum Uncategorised MetalWorking Machines
    Last Post: 11-17-2004, 03:37 AM
  5. Converting a Mill/Drill to CNC
    By NeoMoses in forum Uncategorised MetalWorking Machines
    Last Post: 02-04-2004, 10:29 AM
