603,365 active members*
3,672 visitors online*
    Jun 2007
    3891
    sieg x2 measurements?
    hi, im trying to tweak my kx1 here, and one of the big issues is the head. i think the columns is the same size as the x2 though (yes, its alot bigger then a normal x1), so im wondering if the x2 head might actually fit. will make my life so much easier. so i need some dimensions if anyone is willing to measure.
    1 - column width.
    2 - dovetail width accross the widest point.
    3 - dovetail depth from outermost face to way surface.
    4 - head saddle height (length of dovetail).
    5 - centre of spindle to dovetail way face.
    basically, ive determined 90% of my woes on this machine have to do with the z saddle being an effective 3.6" long, and the ball screw being mounted in the rear with flexy plates. when the ball screw changes direction, the head twists.
    im hoping to use the x2 head and saddle and put the ball screw up front like many mods have.
    Here ya go,
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
    Jun 2007
    3891
    Quote Originally Posted by hoss2006 View Post
    Here ya go,
    Hoss
    nuts! tis 3/4" wider than mine. doesnt look it in the pictures.
    i guess that ideas out.
    merci
  1. Need Help with some Gear Measurements
    By Kain in forum Mechanical Calculations/Engineering Design
    Last Post: 07-17-2009, 03:24 AM
  2. telecaster diagram with measurements
    By woodman08 in forum Musical Instrument Design and Construction
    Last Post: 03-19-2009, 04:09 AM
  3. Powersupply questions (took some measurements)...
    By radioactive in forum CNC Machine Related Electronics
    Last Post: 03-03-2009, 06:12 PM
  4. Do measurements really matter?
    By deleteallusers in forum Linear and Rotary Motion
    Last Post: 02-10-2007, 04:37 PM
  5. Hairline measurements..
    By Rekd in forum Community Club House
    Last Post: 08-27-2003, 05:56 PM
