603,316 active members*
2,154 visitors online*
    Oct 2009
    3
    Siemens 840D controller. Locked in middle of tool change
    1. We power-up the machine (1999 Deckel Maho 103V machining center with Siemens 840D control).
    2. The control shows a flashing light at the tool change buttons (purple and yellow).
    3. When we press the white button to turn on the drives, the tool changer arm swings over into place under the spindle. The prox. switch in the rear lights to show the arm is in place.
    4. We can hear the air operated grips activate (the ones that grab the pull stud on a tool holder).
    5. The Z axis seems about half way down on top of a tool (all tools are out of the machine now for safety).
    6. The machine simply holds in this position and does not move. Air blasting, pull stud puller fingers disengaged, turret in place under the spindle, the spindle not going up or down but is half way in between the tool change.
    We have tried pressing the hand button, bring up the tool change screen and press the yellow and purple buttons back and forth which normally will bring the machine back to 0 in the tool change mode on the screen. Now it is stuck on tool 5 (we cannot get it back to 0).
    If anyone knows of someone in South Eastern Michigan that could service the machine, please forward their name.
    Thank you in advance of any help, Chuck
    Dec 2009
    11
    Exclamation Hello
    Hello Chuck,
    I hope that you have rectified this problem by now. I am a former DMG service tech who is new to this site. If you need help in the future you can email me and I would be glad to assist in any way I can. I live in Windsor so if a visit is needed I can be there in a relatively short amount of time.
    Todd
    [email protected]
  1. Siemens 840D on Deckel machining center. Locked in middle of tool change
    By Chuck - Detroit in forum Controller & Computer Solutions
    Last Post: 10-27-2009, 11:47 AM
  2. Replies: 3
    Last Post: 04-01-2009, 11:06 PM
  3. locked up in middle of program
    By nmn in forum Haas Mills
    Last Post: 03-31-2009, 03:33 AM
  4. VB & Siemens 840D
    By Thunder in forum Visual Basic
    Last Post: 09-22-2007, 04:28 PM
