588,400 active members*
4,990 visitors online*
Results 1 to 4 of 4
    Jun 2006
    40
    Siemens 840d how can i make???
    Hi I have a cnc working center with the Siemens 840d but the first edition the one that has the lcd screen but in monocromatic.
    If i am not wrong the vertion of my software is 3.78 but i am not so sure.
    I worked before with other machines that had Siemens controllers but newer vertions and so when i need to repeat a part of a program i wroted
    N200 BEGIN:
    N210 g01 .....
    END:
    Repeat Begin End p=n(times)
    Now i wroted this in my machine and it arrived at the line 190 and wrote Begin is not a defined variable please ceck the program.,...
    Now i have no idea why the machine wrote this alarm message.
    To everybody who has the Siemens controller:
    PLEASE HELP ME TO UNDERSTAND HOW I CAN REPEAT A PART OF PROGRAM::::
    Thanks :cheers:
    Jun 2006
    40
    NOBODY IS USING THE SIEMENS 840d??????????????????
    Please write something to me i can belive that there is no replies to my thread.
    Apr 2005
    3634
    Can you post your program here, as a .txt file?
    Jan 2013
    474
    try for example.
    AA: (start name)
    G4 F5
    G01 X0Y0Z0.
    G4 F5
    GOTOB AA (GOTOB means go back to target name)
    Note. GOTOF means go forward to when used.
    You can also type
    LOOP
    (prog)
    ENDLOOP
    this does the same as GOTOB in this case.
