603,785 active members*
18,014 visitors online*
Hybrid View
    Feb 2006
    Question Siemens drive problem
    I have a 1986 cnc Lablonde makino lathe with a fanuc 3t control. It has siemens drives. When I power up it blows the two 8 amp fuses on the drive board. I get an error message 10. I can't enable the drives. The machines were made by gildemiester I think.
    Does anyone have any experience with these?
    Feb 2006
    does anyone know if I can get these drives repaired?
    Dec 2003
    24260
    If these are SCR drives, see if you can get a local electronics shop to test the SCR's for shorted condition, if they are and you can find replacements, it may be worth a try.
    What size motors are they?
    Al.
    Albert E.
