603,321 active members*
3,623 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > SIEMENS Sinumerik CNC controls > SIEMENS -> Sinumerik 810M/810T > Siemens Sinumerik 810T GA3 - HALT: EINLESEFREIGABE (STOP: READ-IN ENABLE)
    May 2020
    6
    Hello friends!
    There is a lathe with a Sinumerik 810T GA3 system. The machine was working fine. A notification appeared in Automatic mode HALT: EINLESEFREIGABE (STOP: READ-IN ENABLE) when I pressed the START button. Don't read the sentences now. Even without a sentence entered in MDI and AUTOMATIC, when I press the START button I have this alarm - only the door lock and light are activated. I am asking for advice! I checked the collet tightening - it works. I have the full documentation available. If anyone can read schematics I can send pictures. Please advise what can enable read ban. Thanks to all who can help!
    Mar 2013
    Re: Siemens Sinumerik 810T GA3 - HALT: EINLESEFREIGABE (STOP: READ-IN ENABLE)
    We also had the same error. We identified the problem. The problem was that the spindle encoder belt broke.
  1. Siemens 808DA - Read-in enable missing
    By gvarouha in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 07-05-2021, 08:41 PM
  2. Sinumerik 810T NC Alarm 2000 Ord 1 Emergency Stop
    By corvuscorax4 in forum Mechanical Calculations/Engineering Design
    Last Post: 06-05-2019, 08:06 PM
  3. Replies: 3
    Last Post: 01-12-2011, 05:53 PM
  4. control sinumerik siemens 810T
    By jorgepulido in forum Spanish
    Last Post: 08-17-2010, 04:43 PM
