588,141 active members*
5,935 visitors online*
    Mar 2009
    Siemens Sinumerik older control questions
    Hello. I'm new to this website, so please bear with me. I just started a job with a company that only uses very old equipment, and they put me on a Siemens Sinumerik basic 4c 3t 2-axis turning lathe. The manuals for operating and programming are from 1986 or '87, and are very hard to read. Also, it appears the control panel has been upgraded with features that are not mentioned in the manuals, such as "work cycles," "geometry," etc.
    I've never worked on equipment this old before, so I have several detailed questions about this control. So if anyone knows this particular panel well, can they respond to this posting? Thanks.
    Mar 2009
    The post above is no longer relevant since I'm no longer with the company.
    However, this website, for some reason, is not allowing me to delete the above post. So please ignore the above post. Thanks.
  1. Siemens (sinumerik 802C base line)
    By Afzal in forum Controller & Computer Solutions
    Last Post: 01-16-2013, 02:36 PM
  2. control sinumerik siemens 810T
    By jorgepulido in forum Spanish
    Last Post: 08-17-2010, 04:43 PM
  3. Siemens Sinumerik 810D offsets
    By lenny2007 in forum G-Code Programing
    Last Post: 06-20-2010, 09:57 PM
  4. Sinumerik 3M to pc control
    By jgriffith66 in forum CNC Machine Related Electronics
    Last Post: 11-05-2007, 10:13 AM
  5. Older Fanuc Control
    By Freddy4 in forum DNC Problems and Solutions
    Last Post: 06-18-2007, 03:30 AM
