603,355 active members*
2,861 visitors online*
Thread: sign making
Results 1 to 11 of 11
    Feb 2009
    1290
    sign making
    Our Mistergram Engraver at work just stopped working and they need 2 signs made ASAP. Just some lettering on lamicoid sp?
    All I have is my newly build router and Mach3. Is there some way to quickly do this? I have AutoCAD and can probably get any software I need…
    Is it software that your looking for ?
    you can create some neat stuff with inkscape and save it as dxf http://www.inkscape.org/
    A poet knows no boundary yet he is bound to the boundaries of ones own mind !! ........
    Feb 2009
    1290
    I guess I'm at a loss at how to get a dxf or dwg into Mach3 to route.
    Here is a link to a demo version of SuperCamXp.
    http://www.super-tech.com/root/grp.a...uperCamXp-Demo
    You can import the DXF file and then export the G & M code files. The EXPRTCNC on right sidebar menu will create the G & M code file.
    There are surface, altitude and cut depth parameters that set where the code will occur in the Z coordianate.
    Course if you had a USB CamPod you would not even need Mach3 and you could work directly with the DXF files and the machine.
    SuperCamXp normally comes with the USB CamPod which is a USB to Parallel Port adapter for machine motion control.
    Hope that helps.
    Dennis
    www.super-tech.com
    http://shopcam.com/
    try the demo , its fully functional for 30 days and will produce code , its a product that Ive taken onto my site and I absolutely love it , if you try it then import a 2000dxf .
    here's an aluminum example of something that i was playing with using shopcam today on my day off
    Feb 2009
    1290
    I will give them a try tomorrow after work. Before baseball this evening I downloaded "Font 2 DXF and G-Code 3.0" I got home and exported the DEMOVER test that is all the demo version will allow and it worked flawlessly. I had to tweak the Z depth but it cut the lamicoid perfectly.
    I might like using this CNC router
    Quote Originally Posted by Drools View Post
    I'm sure you will , its a great pass time
    Feb 2009
    1290
    It turns out that the software at work (SignLab) will export to G-code. It has 3 different g-code options gc1, gc2 and gc3 I have no idea what the difference or if the files will load into Mach3 and run. I may have to tinker with the code, but it is a start.
    If I were to post parts of the three export files would someone let me know which one would be better suited to Mach3?
    Mar 2003
    35494
    Sure.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Feb 2009
    1290
    Signlab export gcode examples.
    Attached Files Attached Files
    Feb 2009
    1290
    I do not see a reference to Z in any of the files...
  1. Plasma CNC for Sign Making
    By Robin3295 in forum Waterjet General Topics
    Last Post: 09-06-2016, 06:59 PM
  2. SIGN Making methods?
    By esmiller in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-23-2008, 04:49 PM
  3. Sign making software?
    By jeffmorris in forum Uncategorised CAM Discussion
    Last Post: 04-02-2008, 04:33 PM
  4. simple sign making
    By mc-motorsports in forum Vectric
    Last Post: 03-23-2008, 07:17 AM
  5. BobArt for Sign making?
    By pecosjoe@yahoo. in forum BobCad-Cam
    Last Post: 10-05-2007, 05:52 PM
