Hi to all,
After having built my CNC and using it for quite some things over the past 3 years, I am now venturing into sign making. I have a customer who requires a sign 90cm high x 500cm long, nothing fancy just separate letters which he would like to have them fixed directly to the wall. The letter material is 10mm thick colored Perspex and would like to know if there are any mounting / fixing accessories to do this kind of job as the customer requires.
I figured out that I could get away with cutting twice the amount of letters out of 5mm thick perspex and in 1 set I drill holes to accomodate anchor nails and then stick the other set on top so as to sandwidge them. I then transfer the nail positions in the letters on to the wall, drill and fix them accordingly. But before I do that, I just woundered if there are any accessories available to avoid having to cut the letters twice. Any alternative ideas guys or maybe some pointers where to purchase such things?
Marting
