603,370 active members*
3,497 visitors online*
IndustryArena Forum > CNC Electronics > Phase Converters > Simens AC servo, VFD Spindle drive?
    Nov 2006
    16
    Hi there, i am looking at buying a used Simens 1 FT5066-1AF71-4ABO AC 3 phase servo to use as a spindle motor on a mill drill. Just want to know if a normal VFD can drive this motor, not for positioning. I have a SEW Eurodrive Movitrac 0.37kW/0.5HP VFD Type - MC07A004-2B1-4-00 that i would like to use.
    Thanks for your help
    Mike Christiasnen
    Dec 2003
    24260
    If it is a P.M. servo then you may have a problem, if an induction motor then it should work if the corrent voltage and HP.
    Al.
    Albert E.
    Nov 2006
    16
    yea she is a PM servo. Thanks for that Al, you truly are the Man!
  1. Sweo spindle drive? new mill dead spindle
    By Shizzlemah in forum Fadal
    Last Post: 12-18-2008, 06:11 PM
  2. Using surplus servo motors as spindle drive
    By Swede in forum Servo Motors / Drives
    Last Post: 03-16-2008, 02:05 PM
  3. Can MACH generate +/- 10V to control SERVO spindle Drive?
    By cjchands in forum Mach Software (ArtSoft software)
    Last Post: 07-23-2007, 03:58 AM
  4. simens 840D system parameter setting
    By a_ravi_tn in forum G-Code Programing
    Last Post: 04-17-2007, 03:39 AM
  5. mitsubishi spindle servo drive
    By intermax in forum Servo Motors / Drives
    Last Post: 11-03-2006, 04:15 PM
