587,872 active members*
3,385 visitors online*
    Mar 2008
    simodrive 611
    i have fault 300201 axis x1 drive 1time out bus access,error code 769.i have change power suply ,comounision card of x1,and bus cable but the fault ocour evry few days.i must press the reset buton of ncu to work.any ideas?my email is [email protected]
    Jan 2006
    738
    Check your wires to the motor. Look at points where there is motion for wire damage. Also check motor wiring connections for loose wire.
    Steve
    Mar 2008
    thanks for the answer.the promblem was the cable of taxomert on the drive
  1. Simodrive Problem
    By wanchai101 in forum Servo Motors / Drives
    Last Post: 04-25-2010, 07:27 PM
  2. Simodrive Problem
    Last Post: 07-25-2007, 11:23 PM
