603,354 active members*
3,719 visitors online*
Results 1 to 6 of 6
    Mar 2005
    10
    Simple drill sleeve
    Looking for a quote on a simple drill sleeve. This is used in commercial construction to center a fastener hole through a pre-drilled hole in the material being attached on site. Tolerances can be fairly loose with the exception of OD. This must pass through "Q" size drilled hole. Please quote 100 pieces.
    Thanks,
    Doug
    Aug 2010
    128
    Re: Simple drill sleeve
    What is your concentricity tolerance?
    Mar 2005
    10
    Quote Originally Posted by abcmojave View Post
    I'd like to keep it under 5 thou.
    Thanks,
    Doug
    Feb 2012
    55
    Substitute something for A36? Anything ferrous actually would be better:-). A36 has lousy strength and machining properties, and is not held to tight production standards.
    12L14
    1144SP
    1018
    1045
    4140HT
    Regards.
    Mike
    Mar 2005
    10
    The previous supplier used A36 to keep cost down but there is nothing preventing us from changing material. 12L14 would be a good choice. Given that this sleeve is used in commercial construction and considered disposable, it doesn't have to be a high grade steel.
    Thanks,
    Doug
    Mar 2005
    10
    Thanks for the replies and quotes. This project has been awarded.
    Doug
  1. why wont sprut drill a simple hole?!
    By SomeWhatLost in forum SprutCAM
    Last Post: 07-05-2013, 07:37 PM
  2. Simple Drill subroutine
    By tsaladyga in forum Okuma
    Last Post: 05-17-2012, 01:15 PM
  3. RFQ-simple aluminum sleeve
    By DPowell in forum RFQ (Request for Quote)
    Last Post: 04-05-2011, 09:48 PM
  4. Help setting up a simple automated Drill press
    By MarcusHMM in forum Uncategorised MetalWorking Machines
    Last Post: 03-22-2010, 10:17 PM
  5. SheetCAM TNG simple drill operation
    By BillTodd in forum SheetCam
    Last Post: 12-03-2008, 08:23 PM
