587,322 active members*
3,019 visitors online*
Thread: simple stuff
    Apr 2008
    6
    simple stuff
    I'm trying to cut a 24 inch spherical radius on the end of a 2.750 diameter shaft. I'm using a t plus control. I have in the past drawn out these kind of things in mastercam and plugged in the required values to avoid the frustration that I always run into. When I try to do a radius I enter x=0 for my center of arc x and z=24 for z arc center. I put in 2.75 for my final x and the ?intersect for the final z, x0 and z0 for my starting points. I've tried rearranging these values but to no use. It always tells me DATA MISSING. This is truly frustrating please help.
    Aug 2008
    11
    Mazatrol
    Bar Out (General Out)
    Convex Arc
    Starting Point X = 0.
    Starting Point Z = 0.
    Finishing Point X = 2.75
    Finishing Point Z = 0.039 (-0.039)
    Radius = 24.
    Be sure and check the graphics to see if this works. I haven't tested it.
    You should be able to just run a finish routine to avoid roughing witness marks.
  1. Please Help!! Simple 3-D part not so simple for me
    By eaglegage in forum Mastercam
    Last Post: 05-15-2008, 04:00 PM
  2. Mach3 tuning (cuts small stuff fine, but is off on big stuff)
    By jdbaker in forum Mach Software (ArtSoft software)
    Last Post: 03-15-2007, 05:30 PM
  3. Need a system to run simple CNC for now, but also some whacky(er) stuff in the future
    By nick mulder in forum CNC Machine Related Electronics
    Last Post: 02-27-2007, 01:09 AM
  4. Simple Question Simple Answer ?
    By p3t3rv in forum Stepper Motors / Drives
    Last Post: 02-16-2006, 04:00 PM
  5. welding thick stuff to thin stuff - need advice
    By cross6 in forum Welding Brazing Soldering Sealing
    Last Post: 01-13-2005, 08:39 AM
