603,884 active members*
5,978 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Simulation doesn't work in v22 demo
Results 1 to 4 of 4
    May 2007
    1026
    I've been going through the Getting Started examples in the demo of v22 and can't get the simulation to work. When I try, the simulation window pops up, but all I see is a beige background, and when I hit play, nothing happens, and the progress bar doesn't move or anything.
    I know I have toolpaths since I can see those in the main window, and I've tried to follow the whole thing step-by-step. Are there any "gotchas" that aren't in the documentation or something else I need to know about?
    Feb 2007
    77
    I don't know if the Demo comes with the full Predator Simulation install files. But if you find that (Predator Virtual CNC 2007 for BobCAD.msi), install it and it will fix your problem. Maybe you can download it from BobCAD.
    Steve
    May 2007
    1026
    I think that was it. I ended up buying the basic V22 mill package and after I did the full install it worked as expected. Thanks for the tip.
    Mar 2007
    207
    I have the V 21 version and I have run into the same issue, although I think I am the cause of it. I havent pinned it down yet, But I think it has to do with the 3D button being needed or not needed when you auto cut the tool path.
  1. NC Simulation
    By 5axes in forum Visual Basic
    Last Post: 07-06-2009, 08:57 AM
  2. Simulation in CAMworks
    By Robert Lewis in forum CamWorks
    Last Post: 01-07-2008, 04:38 PM
  3. Simulation problems
    By pineapple in forum EdgeCam
    Last Post: 03-13-2007, 04:40 AM
  4. Simulation only ?
    By patrickb in forum FeatureCAM CAD/CAM
    Last Post: 05-27-2006, 02:01 PM
