587,383 active members*
3,259 visitors online*
Thread: Simulators
Results 1 to 4 of 4
    Apr 2008
    30
    Simulators
    I've got 4 HAAS simulators in my CNC classroom. Can these be hooked up to a PC and run a simulation of the actual machine/tool to see crashes, etc.? Does anyone have experience with this type of thing?
    Jul 2005
    12177
    The Haas Simulator does everything the controller on the machine does except physically move any axes. You can upload and download programs via floppy or usb, whichever is installed, and by RS232. It has the standard Haas editor. You can run programs in Graphics and you can simulate running programs in real time. When you are simulating real time running it gives you position read outs on the axis displays, shows spindle rpm and will give you a close approximation to the actual cycle time for the program on a real machine.
    Apr 2008
    30
    Simulators
    Is there software to actually hook these up to a PC and get a graphical representation of the actual machine moving? So far, they work great on their own. I just wish we had a newer HAAS mill to go along with them. We have a VF0 from 1993...lol!!!! Very small memory makes it difficult to do any 3D surface machining without having to split the program up alot. Hopefully our budget will increase.
    Dec 2005
    439
    No there is no direct PC link/Software that can communicate the way you want with the sim. The sims are a standalone piece of equipment, now with that being said (Geofs post reminded me) there are the RS-232 Ports on the sims you may be able to DNC from the sim in to the machine. I have never tried this, but I do know you can go from one machine to another and the sim thinks its a machine so this should be passable.
    This may be a good temp fix for the lack of memory on the main machine
    I'm not lazy..., I'm efficient!
    HAAS GR-408
  1. Any Mazatrol Simulators/Training Modules?
    By gherlevi in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-10-2006, 07:33 PM
  2. Haas mill simulators.
    By bluechip69 in forum Haas Mills
    Last Post: 11-23-2006, 05:47 PM
  3. CNC program simulators
    By blkexp98 in forum Uncategorised CAM Discussion
    Last Post: 11-22-2006, 04:01 PM
  4. CNC Simulators
    By DFeeney in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-04-2006, 09:13 PM
