Re: Single key on keypad not responding properly.
Originally Posted by
laka
We have an old VF2, 1992 vintage.
The "OFFSET" button on the keypad has stopped working properly. Sometimes if you press it just right and with just the right amount of (hard) pressure, it will work. We have tried swapping in a known working (and much newer) keypad and it does the same thing, although the newer keyboard does seem to work better. Wiggling of wires does not seem to change anything.
We've also swapped out the Keyboard Interface Board inside the control panel, with no change.
I know there is a keyboard/monitor board buried inside the back cabinet, I guess that is our next option. We have a donor parts machine so it's possible for us to swap that and see.
Just thought I'd put it out there if anyone may have any other suggestions.
Swap the keyboard should be the best solution.
