588,080 active members*
4,690 visitors online*
    Aug 2009
    4
    SINUMERIK 810 on Lathe with X, Y, C
    On REF-POINT on X axis I get message "1120 Clamping Monitoring". The machine has 3 axis X Z C. The Z axis is doing the REF-POINT normally. Attached are my software and hardware versions
    Jan 2006
    121
    Re: SINUMERIK 810 on Lathe with X, Y, C
    Hello,
    I think you need to talk to an expert because you have a C-axis, but go to the Siemens Web site and search on the 840T.
    They also have some support. The site is a bit erratic built but try to understand how the tree structure and move on.
  1. Sinumerik 840C, Sinumerik 840D
    By marek-vavra in forum SIEMENS -> Sinumerik 840C
    Last Post: 09-02-2022, 07:04 PM
  2. Replies: 1
    Last Post: 04-27-2015, 03:25 PM
  3. Replies: 3
    Last Post: 10-13-2014, 02:32 PM
  4. NC Code edit software for 2 channel Sinumerik 840D lathe
    By Sergio_plc in forum SIEMENS -> GENERAL
    Last Post: 11-23-2012, 11:51 PM
