603,365 active members*
2,962 visitors online*
IndustryArena Forum > Other Machines > Other Machine Topics > Sinusoidal surface diamond turing.
Results 1 to 1 of 1
    Mar 2017
    5
    Hello,
    My task is to create a turning simulation of the object shown in the attachment and then machine the object. The object will be machined on 3 axis lathe, x,z,c. The lathe is single point diamond turning machine – Nanotech 350 upl. I am looking for a proper software which will allow me to generate g-code and simulate the machining process (toolpath simulations). I was trying to do the simulation in Catia and NX but I couldn’t do it because of sinusoidal surface and software constrains. Any good proposition of CAM software that will help me with my task will be very valuable to me.
    However, if there is a way to generate the turning program and simulation on Catia or NX, please go ahead and describe a way in which I could do it. Thanks, in advance for your reply.
    Here are some links that show videos of the process I will need to use for this part:
    https://www.youtube.com/watch?v=aQyG8aOm7yI
    https://www.youtube.com/watch?v=MUgL9vnATF8
    Thanks, Lukasz
  1. Sinusoidal surface diamond turing
    By bezrenki in forum Uncategorised CAM Discussion
    Last Post: 03-07-2017, 05:03 AM
  2. Sinusoidal surface diamond turing
    By bezrenki in forum Uncategorised CAD Discussion
    Last Post: 03-06-2017, 12:58 PM
  3. Diamond cut end mill surface finish
    By geroge in forum Hobby Discussion
    Last Post: 05-01-2015, 12:32 AM
  4. tap cycle on turing center
    By hackmeister in forum G-Code Programing
    Last Post: 01-30-2010, 05:24 AM
  5. Surface Grinder Wheel - Diamond Dresser question?
    By widgitmaster in forum MetalWork Discussion
    Last Post: 06-27-2006, 06:00 AM
