UIM24002/UIM24004/UIM24008 Stepper Motor Controller with Microstepping
Features:
Miniature Size 42.3mm*42.3mm*13.5mm
Integrally designed to fit onto motors seamlessly, as well as work standalone
10-40VDC supply, Max 2A/4A/8A adjustable output current, 1to16 Microstepping
Dual H-bridge with PWM constant current control,
Enable/shutdown controllable
Opto isolated inputs with common anode.
Die-cast aluminum enclosure
Overview
UIM24002/24004/24008 is a series of miniature, high performance stepper motor controller. They can be mounted onto 42/57/86/110 series stepper motor seamless through corresponding flanges. The thickness of these controllers is less than 14mm, UIM 24002 is capable to provide 0.5-2A adjustable current. UIM 24004 is capable for 1.6-4A adjustable current output. UIM24008 is capable for 2A-8A.adjustable current output. Their mixed-decay current control reduces the back-EMF effect under high speed running condition and improves the performance. Except the UIM24002 takes 10-35VDC input, UIM240xx series controllers can work with 12 to 40VDC input.. Enclosures of the UIM240xx controller are made of die-cast aluminum which provide a rugged and durable protection and improve the heat dissipation..
Absolute Maximum Ratings
Supply Voltage 12~40VDC (10~35VDC for UIM24002)
Current input at logic pins: +/- 30mA
Storage Temperature -20℃ - +125℃
Operating Temperature -20℃ - +85℃
Note: Stresses beyond those listed under “absolute maximum ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated under “recommended operating conditions” is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability.
Electrical Characteristics (Ambient Temperature Ta = 25℃)
Supply Voltage: 12-40V DC (10~35VDC for UIM24002)
Output Phase Current: Max 2A/4A/8A (1)
Current Control: Constant, PWM control
Microstepping: Full-, Half-, Quarter- and 16th-step (2)
Photocoupler Isolation voltage: 2500 Vrms (min)
Photocoupler Input current: MAX +/- 45mA
Note:
(1) adjustable through on-board POT
(2) adjustable through on-board DIP switch
Communication: 3-wire, Step, Direction, and Enable signals
Handling, Storage and Size:
Cooling Type: Free air
Working Environment: Free of heavy dust, oil mist and corrosive gas
Ambient Temperature: -20℃﹋+50℃
Humidity: Lower than 80%RH, no condensation and frost
Vibration: 1G Max
Storage Temperature: -20℃ - +125℃
Dimensions: 42.3mm*42.3mm*13.5mm
Weight: 0.1kg
UIM24104/UIM24108 Stepper Motor Controller with RS232 interface
Feature:
Embedded DSP microprocessor, in-line operation through RS232
Smart, fault-tolerating and user-friendly interface.
RS232 3-wire serial communication, max 115200 bps, automatic host Baud Rate detecting
12-40VDC supply, max 4A/8A adjustable current , 1-16 Microstepping
Dual H-bridge, PWM constant current control
Overview:
UIM24104/24108 are miniature, intelligent stepper motor controller using the RS232 protocol for communicating with user devices/controllers. They can be mounted onto 42/57/86/110 series stepper motors seamlessly through corresponding flanges. The thickness of these controllers is less than 14 millimeter. The embedded high performance DSP microprocessor accepts user commands in ASCII code style through RS232 protocol. The structure of the instructions (i.e. commands from user) is simple, straightforward and fault-tolerating. Users are not required to have the knowledge of stepper motor driving. Enclosures of UIM24104/24108 are made of die-cast aluminum which provide a rugged and durable protection to the controller and improve the heat dissipation.
RS232 interface
RX to GND Voltages.......................................... .......................±25V
TX to GND Voltages.......................................... ........................±13.2V
Short-Circuit Duration TX to GND............................................... ............Continuous
Note:
(1) Actual current is set by user RS232 instruction and is real-time adjustable
(2) The value is read from the DIP switch at power-on, and is real-time adjustable by user RS232 instruction
Communication: 3-wire RS232 protocol
Vibration: 1G Max
Weight: 0.1kg
UIM24204/UIM24208 Stepper Motor Controller with CAN2.0
Product Feature:
Embedded DSP microprocessor, CAN2.0 network, and RS232 interface
Smart, fault-tolerating and user friendly interface
CAN2.0 2-wire communication, max 1 Mega bps, max 10 Kilometers transfer distance and highly noise immunity
12-40VDC supply, max 4A/8A adjustable current , 1-16 microstepping
Overview
UIM24204/24208 are miniature, intelligent stepper motor controllers equipped with CAN (control area network) bus for building up local motor network. By using these motor controllers, user can control multiple motors in real-time. To communicate with these motor controllers, user needs one CAN-RS232 converter (UIM250, sold separately). The UIM250 CAN-RS232 converter communicates with the user devices/controllers through RS232 protocol using ASCII codes. Through this fashion, users can operate these controllers with minor or no knowledge about the stepper motor driving and CAN bus. The structure of the instructions (i.e. commands from user) is simple, straightforward and fault-tolerating. UIM24204/24208 can be mounted onto 42/57/86/110 series stepper motors seamlessly through corresponding flanges. The thickness of these controllers is less than 14 millimeter. Enclosures of UIM24204/24208 are made of die-cast aluminum which provide a rugged and durable protection to the controller and improve the heat dissipation..
CAN interface
DC Voltage at CANH, CANL (Note 1) .................................................. .......... -42V to +42V
Transient Voltage on Pins 3 and 4 (Note 2) .................................................. ..-250V to +250V
ESD protection on CANH and CANL pins (Note 3) .........................................6 kV
ESD protection on all other pins (Note 3) .................................................. ......4 kV
Note 1: Short-circuit applied when TXD is high and low.
2: In accordance with ISO-7637.
3: Classification A: Human Body Model.
Note:
Communication: 2-wire CAN 2.0B CAN1.0, CAN2.0A, CAN2.0B optional
CAN bus drive
• Supports 1 Mb/s operation
• longest distance 10,000 meters
• Implements ISO-11898 standard physical layer requirements
• Suitable for 12V and 24V systems
• Detection of ground fault (permanent dominant) on TXD input
• Power-on reset and voltage brown-out protection
• An unpowered node or brown-out event will not disturb the CAN bus
• Protection against damage due to short-circuit conditions (positive or negative battery voltage)
• Protection against high-voltage transients • Automatic thermal shutdown protection
• Up to 100 nodes can be connected
• High noise immunity due to differential bus implementation
Vibration: 1G Max
Weight: 0.1kg
UIM24302 Micro stepper motor controller
Feature:
Micro Size, 16mm*24mm*2.5mm
Embedded stepping pulse generator, adjustable frequency
ON/OFF, Reset, Direction 3-wire control
10-35V DC, 2A adjustable phase current, 16 microstepping
TTL Logic control
Overview:
UIM24302 is a high performance stepper motor controller that features micro miniature size and 2A max phase current. The size is only 16mm*24mm*2.5mm. Onboard 555 timer based stepping pulse generator unit eliminates the need for external pulse source. The pulse frequency is adjusted through an onboard potentiometer. Once the frequency is set, user only needs 2 signals to control the motor: on/off, direction. The Reset signal input can put the controller into sleep to maximum the power saving. If not needed, leave it open.
We also offer quick engineering design service to satisfy the needs of single power supply, different microstepping options, photocoupler isolation and embedded control system, etc.
Supply Voltage 10~35VDC
Current input at logic pins: +/- 20mA
Supply Voltage: 10~35VDC
Microstepping: 16th-step
Vibration: 1G Max
Weight: 0.1kg
