Here are the stats for the servos.
Rated voltage: 24 VDC
50 oz-in continuous torque
410 oz-in peak torque
No load speed 3,211 rpm
Torque constant (Kt) = 10 oz-in / amp
Voltage constant (Ke) = 7.39 volts / krpm
How large a power supply do I need for this motor? 41 amps seems a bit unrealistic. If I am running 3 of these motors from a single power supply can I reduce the total amperage?
