603,802 active members*
3,854 visitors online*
Page 3 of 4 1234
Results 41 to 60 of 67
  1. #41
    Nov 2006
    93
    Last question, do you have some cad drawings of your gentry?
    I am using a machmate machine but with simular to your gentry.
    I need dimensions of steel profiles used...
    I can show you a cad drwaing of my machine...
  2. #42
    May 2006
    102
    Here you go, Goos80 (with a name like that arn't you feeling nervous at this time of year ) dxf of the Y axis, only uses 25 x 25 x 1.5mm tube and is really solid with minimal weight, though with that servo... and the spindle weight 15kg I think... It's still a heavy lump though I can still move it easily enough.
    Usual discalimer with the drawings - if you break you leg don't come running to me
    At this point I'm not sure about the uprights, I think they might sway so there could be come external bracing to do
    Attached Files Attached Files
  3. #43
    Nov 2006
    93
    Hehe, We in Norway are not Eating Ducks and Gooses for xmas so this time I not concern
    Thank you for DXF. It will help me a lot. The only think is that I am using another support for Y-axis.
    As for the weight I am not afraid. I will use 1160Oz-in motors and If they are to week I can always gear them ones or twise as you done.
    And with Gecko 203V it will fork very well...
  4. #44
    Nov 2006
    93
    Are you using M8 screw to support shafts?
  5. #45
    Nov 2006
    93
    Hello.
    What is a specification of belts you are using?
  6. #46
    May 2006
    102
    Hi Goose80,
    I'm sure I put a reply to no.44 - I'll do it again..
    Yes M8 studs evry 300-400mm otherwise it'll bend, despite being 25mm solid diameter
    I'm using 15mm wide belts in T5 form - that's 5mm pitch & here's the guy I got them from in Holland. Great guy gets my vote!
    http://www.stappenmotor.nl/
    does good english, a bit of french & erm, dutch I guess:lol
  7. #47
    May 2006
    102
    Talking One great step for routers...
    :banana: I think this deserves a dancing banana!
    A quiet xmas. Kept all the relatives away and got to work in my playroom. The table is basically made, still got to do some braces below, when I've decided how high to mount them. The legs will have adjustable feet though at the mo wheels would be better due to cramped building conditions.
    The gantry whizzes up and down superbly, there is some whip, wiggling, but when the belts are connected I don't think this will be an issue.
    I can see the light at the end of the tunnel although it's a only a pinprick at the minute
    I think I must have perfected the perfect router table here as nobody has chirped in
  8. #48
    Sep 2005
    249
    I have to admit, I'm waiting on building my CNC router, until I have my CNC mill done, so I can build something very similar to your rollers. It will be a cross between your idea and some others. I really do like your design. One question though, that table with those legs seems like it would be pretty wobbly. Are you going to reinforce it? Maybe some cross braces? Kudos on your progress so far! :rainfro:
  9. #49
    May 2006
    102
    Yeah, I know what you mean about wobbly, I thought that too when it was on the drawing board. It really suprised me that it's so solid. But yes there is some bracing to put in. I've got an enclosure to mount underneath so I'm gonna put braces to mount that. kill 2 birds with one stone so to speak
    I would imagine that if I left it like that it would move about doing some rapids.
    Do the cnc mill to do the router... I know the feeling. so many catch 22's !
  10. #50
    Jul 2006
    1062
    Quote Originally Posted by la_coterie View Post
    Be aware that the light at the end of the tunnel can be a guy with a torch bringing more work.... Sorry it just struck me as funny
    Keith
  11. #51
    May 2006
    102
    love it
  12. #52
    Nov 2005
    105
    I have these servo motors with encoders, made by Shinano Kenshi, 30volt 1.5amp.
    If anyone wants them, let me know.
    Live life like you never see another day
  13. #53
    May 2006
    102
    (wrong)
  14. #54
    May 2006
    102
    Video of rapids
    Hi All,
    Been a while, I've rather busy with business but now things are moving on again.
    I've attached a video link for your amusement of the Y axis doing 21m/min
    http://video.google.co.uk/videoplay?...98931643396274
    www.la-coterie.com for holidays in France
  15. #55
    Dec 2005
    238
    Great looking linear bearing
    Like the look of your skate-o-rail. Think I will try and build one this weekend to see how it goes. As a suggestion how would it go if the 2 center plates were removed and the 25mm x 10mm steel with the bearings in them went end to end. I find it hard to believe that steel that heavy will flex over that distance but I have been wrong before. This would mean only 2 end plates would need to be machined making construction easier but maybe you have already tried this.
    Your machine looks great. I hope my next one looks as good.
    Cheers
    Peter
    Once I thought I was wrong but I was mistaken!
  16. #56
    May 2006
    102
    Yeah I thought of that, after the event. I guess it will depend how far apart the 2 ends are.
    I reckon it would work with 200mm between then assuming the bearings are near each end.
    The only slight concern I would have is the reducing of the mounting points for the gantry & Z axis.
    Keep me informed, as you say it halves the plates to make and I'm all for that!
  17. #57
    Dec 2005
    Great execution. Please report back on the half plate experience. I've got some 1.5" linear rail I've got to make bearings for and this looks like the ticket. Even better if the number of plates could be reduced by half.
  18. #58
    May 2006
    102
    Well has it really been 18months since I started this thread!
    I guess that's the problem with hobbies - they take the back burner when work gets in the way.
    The router is more - or - less finished and has cut some great signs. I still need to make something to adjust each side of the X axis so that it will cut a real square but it's not far out as it sits.
    I'll post some piccys in the next couple of days and give some more insight on my findings with this design.
  19. #59
    May 2006
    102
    Here's a few shots as it stands now, sorry the photos seem fuzzy.
    I've got to take it apart shortly to move & paint it, something I'm not looking forward to
    The design:
    the table is made from 80 x 40 x 3mm tube and it rock solid. I should have made the gantry out of it as well weight straight down is fine but it can be made to twist.
    Belt drive - does it work?
    so so, would I use it again - no. I have steel braced T5 x 15 on the X and that still has some give on it. I could probably tension it some more if I had more adjustment. (This is a 120cm x 120cm travel machine) on a smaller machine I guess it would be acceptable...maybe.
    Yes, some might say the belts are too small but then buying bigger belts would probably be as expensive as ballscrews! If starting from the begining again I think I would use ballscrews, in the end it doesn't come out any more expensive.
    The X is driven both sides and the side without the motor does seem weaker which I put down to the size of the cross shaft - only 15mm over 1300mm so it does wind up, I'm guessing I need something about 30mm But I knew that when I started
    Ideally the gantry uprights need angling so that the cutter force comes down inbetween the X carriages, and Aluminium for them is a waste of time - too much flex despite being 10mm. Go get a decent lump of half inch steel plate
    I use Mach Quantum which suits this machine rather well. cutting the road runner file on normal Mach3 was horrendous, immediatly suggesting things need beefing up
    On the good side, my home brew rails seem to do the job, as best I can tell, time will tell.
    Would I do it again? not like that, but then thats what the experience is about.
    save yourself the grief & uncertainty and go and buy some linear rails and ball screws and a load of industrial strength steel tube!
    At least I've got my Tee shirt now
    Attached Thumbnails Attached Thumbnails DSCF0053.jpg   DSCF0054.jpg   DSCF0055.jpg   DSCF0056.jpg
  20. #60
    May 2006
    102
    Just a couple of piccies of it painted - only has one coat but looks much better. I changed the rear cross shaft for one of 25mm, but I haven't actually used it in anger since doing it...
    It had to come out of its original build placeandmore to this "hole" thats not much bigger than the actual router! It is in fact all back together now and has been for a long time, I'm just rather lazy in getting some electric to it.
    Attached Thumbnails Attached Thumbnails DSCF0088.jpg   DSCF0089.jpg   DSCF0090.jpg   DSCF0091.jpg
Page 3 of 4 1234
  1. Questions on rail covers, dual servo hunting,and rail preload
    By Plugger in forum Uncategorised MetalWorking Machines
    Last Post: 05-14-2011, 05:00 AM
  2. Patent?
    By rweatherly in forum Vectric
    Last Post: 02-01-2010, 04:16 PM
  3. Light duty skate-O-rail
    By Rhodan in forum DIY CNC Router Table Machines
    Last Post: 10-25-2007, 05:25 AM
  4. A question on bearings......to skate or not to skate
    By HiString in forum DIY CNC Router Table Machines
    Last Post: 11-12-2003, 08:46 AM
