I have a Dynatorch and have installed the updates about two weeks ago. After nesting the parts I can manually scroll thru the code and it looks fine . I am cutting 15 parts out of each 4'x10' sheet which each part has 2-2' holes cut in it . Everything does fine except the the last row of 3 parts.It only cuts the one hole then goes to the next and pierces,but doesn't finish the hole, then it finishes cutting the part to size. I nested this in the converter under special save. Anybody have any ideas?![]()
