![Quote](images/misc/quote_icon.png)
Originally Posted by
Guldberg
Finally I finished both the toothed rims and could assemble the turret mechanism. It can be turned by hand, so I hope the stepper wont have a problem turning it.
I did a sample of the cover for the Z axis. This is going to work just fine
dear guldberg,
luckily, i just finished my lathe project and it is running now with two tools only. I am building a turret now (try to copy you). the problem is that i have no experience with pneumatic. i have a compressor that delievers upto 100psi. (we use that for painting out machines, hope the same will work). i am looking for a decent cylinder that can push my turret. do you think this type of cylinder will work?
http://cgi.ebay.com/SMC-Pneumatics-A...item4ced6e997d
if not then please suggest me an item that should be enough to push the toolplate and springs of the turret. btw what size of cylinder and compressor you have used in your turret?
You have good experience with all these things so i will be thankful for your help.
jasminder singh
It is better to die for something than to live for nothing.
