603,976 active members*
2,828 visitors online*
Results 1 to 4 of 4
    Jun 2014
    Slave axis motor turning slower only sometimes.
    I have slaved my A axis to my X axis. What happens is that the A will be off because it turns slower only sometimes. I have swapped motors drivers and power supplys. Thank you in advance
    Nov 2013
    88
    Re: Slave axis motor turning slower only sometimes.
    It may not be running slower, if the machine is not binding up then it could be missing steps.
    If you still need help, then describe the pc and software your using.
    Jun 2014
    Thank You for responding I have mach3 on a dell tower. I switched the pin outputs in mach and the problem stays the same. I then swap the outputs of the controller and the problem changes. I put the connections back at the controller and swap the drivers and the problem is the same. I am using a ebay purchased breakout board controller and seperate drivers.
    Nov 2013
    88
    What are the settings you have for,
    ports and pins: kernal speed
    motor tuning: step pulse
    motor tuning: dir pulse
  1. Dual Y Axis Slave A Axis Homing Problems
    By guy2b1 in forum Calibration / Measurement
    Last Post: 03-03-2012, 11:06 PM
  2. X axis travel rate is 50% slower than Y
    By Inuk in forum Stepper Motors / Drives
    Last Post: 12-29-2010, 08:21 PM
  3. X axis runs 50% slower than Y
    By Inuk in forum Excitech routers
    Last Post: 12-27-2010, 03:05 AM
  4. Replies: 8
    Last Post: 10-29-2009, 02:09 PM
  5. How to invert slave motor direction?
    By toolbox911 in forum Stepper Motors / Drives
    Last Post: 02-14-2006, 04:16 PM
