Hello supertechster,
The Gingery machines are a series of machines designed by Dave Gignery. Each machine is the topic of a book and he made the metal lathe, metal shaper, and horizontal milling machine books. Prior to doing the build for these machines he also has a 'make your own foundry' book that teaches you how to make a small foundry and use it to melt scrap aluminum, make green sand molds, and cast your parts from wooden patterns.
The pictured machines in the previous picture are the shaper and the horizontal milling machine, so that is actually 2 machines. The milling machine actually has lathe characteristics and can be used for turning and facing, but I have not finished the tailstock for the miller yet. They are good metal working machines but like any machine they have their limitations, although the milling machine has saved the day for me when my SX3 CNC mill motor electronics went bad.
If you do the Gingery series of machines the metal lathe is the first machine to build and then you use that to make the shaper and milling machine. Along the way as you get a machine done or partially done you are shown how to use what you have to get further along. I would recommend the Gingery series very highly, but I'm sure glad I am not just starting with the Gingery machines.
It took me probably 10 years to get the Gingery machines I have built done just working evenings, weekends, or whenever time permitted. It is a lot of work including wood pattern making, green sand molding, and then pouring the molten metal. The catch is when the casting is poured, it is still not done, but there is a lot less work left to do than some other methods of fabrication and the part is a solid piece. Sorry, I didn't mean to go overboard with the reply. I'll check back tomorrow.
Regards,
