This is the beginning of a small mill I am building hopefully it will be a little more rigid than the standard X2 kind of a struggle as I don't have access to a milling machine used to where I was working but I'm laid off so I started to put it together the spindle I started about two years ago just put on the back burner made the spacer block mounted the DC treadmill motor at that time here is a couple pictures![]()
