587,220 active members*
2,858 visitors online*
IndustryArena Forum > Employment Opportunity / RFQ (Request for Quote). > Employment Opportunity > Small quantity Acrylic/Clear Plastic Sheets with Simple Cuts
Results 1 to 7 of 7
    Dec 2009
    22
    I don't have a drawing now but the design is very simple. 18"x12" acrylic sheet with 6x drilled holes and a 8.5x11x0.060" depression milled in the center. I'm located in LA and commute to OC often so something in that area would be best. Feel free to suggest a material easier to machine than acrylic - must be a plastic and preferably clear.
    Thanks in advance.
    Aug 2010
    Quote Originally Posted by Johnnybgood3 View Post
    Thanks in advance.
    I am in Montana, but would be interested if you couldn't find someone close.
    Sep 2009
    313
    I'm in Arizona and would also like to quote and shipping would be really cheap. Let us know if your interested and we can work through this with you. Thanks
    Dec 2009
    22
    Sure that would be fine, I don't mind having it shipped. Could you guys provide an estimate of the order of magnitude I'm looking at in terms of the price plus what quantity discounts would be?
    Sep 2009
    313
    How many machined sheets do you need? I also have better materials in mind that are a million or more times stronger and easier to machine then your acrylic.
    Dec 2009
    22
    I need very few.. At first I will get just one at a time until I verify that the design actually works as intended. Afterwards I will probably buy a few at a time given that I expect them to wear down over time.
    Dec 2009
    22
    I've attached a DWG of 8 drill holes and counterbores I want added to a 1/2" thick piece of Acrylic or other plastic you. This is a slight change from my original request.
    Attached Files Attached Files
  1. 50mm thick Acrylic Clear offcuts
    By didja_do in forum Australia, New Zealand Club House
    Last Post: 02-17-2009, 08:26 AM
  2. Need a Small Quantity of Acrylic Sheet Cut
    By marshall1 in forum Employment Opportunity
    Last Post: 01-13-2009, 01:44 AM
  3. small quantity plastic source?
    By zcases in forum Glass, Plastic and Stone
    Last Post: 01-02-2007, 06:20 PM
  4. Looking for small, simple, manual lathe work, any quantity
    By sanddrag in forum Employment Opportunity
    Last Post: 08-02-2006, 02:31 AM
  5. Clear Acrylic Fender Stratocaster Guitar
    By HygloCompany in forum Glass, Plastic and Stone
    Last Post: 02-17-2006, 06:49 PM
