603,979 active members*
3,263 visitors online*
IndustryArena Forum > WoodWorking > WoodWorking Topics > small size router bits
Results 1 to 9 of 9
    Jul 2008
    17
    Hello,
    Where can I find small sizes router bits for cnc wood carving? I need 1/32" cutting diameter and smaller.
    Thanks,
    Ghazi
    Mar 2003
    35494
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Jul 2008
    17
    Thanks Gerry.
    Ghazi
    Dec 2007
    33
    Tiny router bits
    Jul 2008
    17
    Thanks.
    Ghazi
    Ghazi,
    Check out Microcut (www.microcutusa.com) they have a good selection of bits. They sell through local distributors. I usually order and receive the cutters in the same week. I use them on all my machines. I use .0312, .0625, .125 carbide mills, both ball-end and flat for 90% of my work and they last a long time. The biggest problem I have is breakage (mostly due to operator error) especially in the smallest sizes. I make 1/12-scale tractor parts in Maple and Cherry, and these are small parts.
    I made tool holders .500 diameter to fit my Porter-Cable routers. They hold a .125 diameter cutter shank.
    The ball-end cutters do a great job when doing 3D toolpath cutting.
    Hope this helps!
    Doug
    www.woodntractors.com
    Jul 2008
    17
    Thanks a lot Doug. I will check if they have distributors in Canada.
    Ghazi
    Jun 2007
    71
    Oct 2007
    1072
    try tate industrial windsor ont 1 800 265 3814 tell them stan from kincardine send you
  1. Sharpening Small Bits
    By ToyMaker in forum Toolgrinding / Toolgrinding Machines
    Last Post: 01-09-2017, 08:02 PM
  2. Where to buy router bits
    By ronateah in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 09-16-2011, 11:03 AM
  3. Poll: What size(s) Tool Bits do you Use The Most?
    By elwoodbeauchamp in forum Polls
    Last Post: 12-02-2007, 04:33 PM
  4. Looking for small steppers, 14, 16, 17 size
    By RomanG in forum Stepper Motors / Drives
    Last Post: 11-03-2007, 05:41 PM
  5. Using a router for the 1st time. Need advice of cut speeds, router bits etc.
    By Apples in forum DIY CNC Router Table Machines
    Last Post: 09-23-2006, 09:33 PM
