587,125 active members*
3,262 visitors online*
Results 1 to 8 of 8
    Jul 2005
    113
    Small Vacuum Table
    I have just uploaded a small Vacuum bed for anyone interested in making one.
    It is not a Venturi type but tradditional suction.
    As usual pictures and Gcode available.
    Best Regards
    Sean.
    Feb 2005
    921
    Very nice, what do you use for the vacuum source?
    Jul 2005
    113
    Hi CNCRob
    Sorry I forgot to put the link!
    There is a picture of my Vacuum unit on the example page along with the Gcode and pictures showing it being made at http://www.cncdudez.com
    It is not an over powerfull with 1kw motor and 53 Litre a second Air Flow but does the job.
    Regards
    Sean.
    Dec 2004
    1316
    That's a clean looking job, I think I will take a crack at that.
    Thanks for the code.
    Jason
    Are the holes tapered for easy plugging of the uncovered holes with rubber stoppers?
    Eric
    www.widgitmaster.com
    It's not what you take away, it's what you are left with that counts!
    Jul 2005
    113
    Hi Eric
    The holes are just straight through and not tapered.
    But that is not a bad idea, where would you get little rubber stoppers from?
    At the moment you can just use masking tape to cover any unused holes or even paper if holding down material for engraving.
    Regards
    Sean.
    Quote Originally Posted by widgitmaster
    Eric
    Cool
    Quote Originally Posted by CLaNZeR
    Actually, it would be easier to make them yourself by mixing up some ReproRubber casting material, as it should follow the contour and not stick to the smooth surfaces!
    http://www.smallparts.com/products/descriptions/rep.cfm
    The taperd holes are easily made in a drill press, using a 1/8 tapered pipe reamer !
    They can be found in hardware stores, or ordered online from Enco
    Then you get a perfect seal!
    Eric
    Jul 2005
    113
    Hi Eric
    Thanks for the link, that looks interesting stuff to play with and would indeed to the job.
    Might look at something like that in the future.
    Regards
    Sean.
