603,978 active members*
1,682 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > small vs large stepper motor
Results 1 to 5 of 5
    Aug 2007
    55
    Given these two motors, when wired bipolar parallel:
    http://www.kelinginc.net/KL23H286-20-08B.pdf
    425 oz-in
    2.8A
    4.17V
    http://www.kelinginc.net/KL23H276-30-8B.pdf
    282 oz-in
    4.2A
    1.9V
    Does that mean to get the rated torque out of the 282 motor, I would need a driver with a higher current rating than to get the rated torque out of the 425 motor? But to get higher rapids on the 425, I would need a driver with a greater voltage rating?
    I think the 282 motor is enough for my application, but I don't want to use it if it would require a bigger driver than the 425.
    Mar 2003
    35494
    Yes, you're correct. Holding torque is proportional to current, so you'd need a 4.2amp drive to get full holding torque from the 282oz motor, but only 2.5amps for the 425. Supplying higher voltages keeps the torque from dropping off quickly at higher speeds.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Aug 2007
    55
    Then why do some people choose the smaller motor for small milling machines, given that you need a more powerful (expensive) driver to run it, and very fast rapids are not needed in small mills?
    Sep 2006
    104
    Perhaps they run it Bipolar series instead, and fast rapids are nice even on a small mill.
    Jan 2005
    224
    Has anybody tried/used two smaller steppers per axis?
    The thought being it could give more power at higher speed (minimizing the inductance compared to one larger rotor) but still provide similar low speed torque to that of a bigger motor.
    Just wondered if this is feasible.
    Pres
  1. Small or large jobs wanted for 5 axis cnc (woodworking)
    By Shawnm in forum Employment Opportunity
    Last Post: 04-13-2011, 08:38 PM
  2. Stepper for large mill ???
    By Guido72 in forum Stepper Motors / Drives
    Last Post: 01-13-2008, 08:13 PM
  3. 340 or 320 with large motor
    By johnd in forum Gecko Drives
    Last Post: 05-11-2005, 09:07 PM
  4. Using a large drive on small motor?
    By murphy625 in forum CNC Machine Related Electronics
    Last Post: 03-11-2005, 11:23 PM
  5. How to Run a Large Stepper On A Small Board without frying
    By Sanghera in forum CNC Machine Related Electronics
    Last Post: 04-27-2004, 11:39 PM
