587,331 active members*
3,412 visitors online*
Results 1 to 6 of 6
    Jan 2006
    88
    Smokey transformer - oh dear
    I burned a transformer a bit today ...
    details withheld ! But in the interests of safety, get someone who knows what they're up to and don't rely on what you read on the net !
    Jun 2007
    3734
    Whoa!
    I think you put a short on one primary(RED to BLACK) and put 240v into the other 115v primary (RED and BLACK)
    Turn it off!
    The red and black you connected together, I guess were on the same winding.
    Identify each winding with a multimeter, measuring the resistance.
    Now put them in, what you assume to be series and measure the total resistance. It should be double of what a single winding is.
    If not, think again, but don't power it up until you are sure.
    It might survive. Time will tell.
    It is easy to get the smoke out, and hard to get it back in again.
    Super X3. 3600rpm. Sheridan 6"x24" Lathe + more. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
    Jan 2006
    88
    I burned a transformer a bit today ... Still going, and no damage to the cats but details withheld ! In the interests of safety, get someone who knows what they're up to and don't rely on what you read on the net !
    (thanks Neil for the reply)
    Jun 2007
    3734
    If you run it with the black to black, and red to red, as you did, it will eventually cook (unless you only run it on 115vAC)
    Nov 2005
    1468
    Don't transformers have nasty chemicals in them like PCBs? (polychloro biphenols)
    I love deadlines- I like the whooshing sound they make as they fly by.
    Jan 2006
    738
    No PCBs... at least not since the late 70's... and not unless they are sealed so the liquid would not leak out. They were used as a cooling fluid in large power transformers and some flourescent lamp balasts, as well as some high voltage capacitors. It also has high dielectric strength to suppress arcing.
    Steve
  1. Once more into the breach, dear friends.
    By chipzilla in forum Joes CNC Model 2006
    Last Post: 05-26-2012, 10:38 PM
  2. Dear Friends on CNCzone...
    By Taney118 in forum Excitech routers
    Last Post: 05-13-2009, 01:18 AM
  3. Dear Penthouse....
    By buddym in forum DIY CNC Router Table Machines
    Last Post: 02-10-2009, 04:44 PM
  4. Dear every body!
    By stevent in forum News Announcements
    Last Post: 07-20-2008, 09:30 AM
  5. Spindle Motor, Smokey, Sparky...
    By thebighorn in forum Uncategorised MetalWorking Machines
    Last Post: 08-02-2007, 03:20 AM
