Attached is a pic of the cnc lathe that I got this year. It uses a horizontal laminate trimmer as the cutting tool. I've been turning wood and acrylic and using a triple fluted upcut solid carbide router bit. It removes the material well enough I suppose but leaves a rough surface. Does anyone have any suggestions on what type of bit to use to get a smooth, or at least as smooth as possible finish. Perhaps an v-grooving bit. I'm tired of sanding and polishing. especially the acrylic.
thanks,
dh
