When I try to cut a solid with pockets I can't get the function to work. Also when I generate a tool path its just a series of holes instead of outlining the part in a smooth fashion around the outside of the part. This isn't a problem with a flat surface but once its extrude into a solid or if a solid iges file is importe no pockets or smooth outline.
