Smooth Stepper v\s Parrallel ports !
I just had a series of changes, one of which was my pc got hammered. I put together a new one with an AMD phenom @ 3010 Hz so now proc speed is no issue. I discovered that due to the Pci slots I had to use, that the addresses didn't want to play nice with Mach, this may well have been due to a changes in the BIOS and I couldn't deal with it, so I ordered the Smooth Stepper board. I had a number of issues going on all at the same time, so the set-up wasn't painless, but I found an old enemy hiding in the shadows and re-gained my mach settings then did the finish tune-in with the SS and I am happy as clam.
I just wanted to say that the SS using the usb port is clean and works good. With mach set at 25,000, SS takes over and provides more servo driving potential than I could use or feel safe with. If with the advent of new computers making it more difficult to use the parallel ports then the SS really would solve the problem and even without that it is still an excellent choice.
I have had many issues with breakout boards and with that was a bit apprehensive about the change, but now that I'm running it as stated above I'm a happy camper and ready to get back to making chips fly.
In closing I really want to say that the machine has never run so smoothly or strong as it is right now. I'm hoping it isn't too soon to say this as I always seem to end up with an unhappy aftermath. Time will tell the story for sure. Also the cost of the SS may seem high but the results seem well worth every cent so far !
Don
IH v-3 early model owner
