603,936 active members*
2,141 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Software for convert grbl A commands in grbl X commands
    Hello everybody,
    I m hobbist tryng to use a 4th axe with X swapping , because my low cost machine has only 3 axes.
    I ve found some cam ,for rotational 4th axes, but outputs A +degrees commands.
    Know some software to convert A commands in X commands.
    Thanks a lot
    Mar 2016
    365
    Re: Software for convert grbl A commands in grbl X commands
    Notepad
    Ctrl+H
  1. Software to convert in grbl some well know gcode type
    By SeinUndZeit in forum Uncategorised CAM Discussion
    Last Post: 09-12-2024, 02:17 PM
  2. Machine recognizing T## commands (no M06) as tool change commands
    By TravisDoenThings in forum Uncategorised CAM Discussion
    Last Post: 10-27-2023, 09:53 PM
  3. Replies: 7
    Last Post: 01-20-2021, 08:03 AM
  4. Commands for a complete work home sequence using GRBL?
    By kevinol in forum Chinese Machines
    Last Post: 10-16-2019, 03:46 PM
  5. Replies: 1
    Last Post: 08-19-2016, 11:57 AM
